Heat Sewing Machine
A revolutionary device that retrofits electric sewing machines to convert them into affordable heat-sealers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
Jon wrote 09/02/2020 at 18:50 • point
I'm interested to hear about different applications you might have considered, even outside of the Hackaday Prize challenge. Making even a low-cost fabric cutter/sealer might be a valuable application... as long as you aren't ridding the world of a worthy sewing machine. Good luck!
Dan Maloney wrote 06/09/2020 at 16:56 • point
Sounds like you should check out the challenge laid down by Field Ready for the 2020 Hackaday Prize for a portable heat sealer for disaster response: https://cdn.hackaday.io/files/8533365075872/design-brief-fieldready-open-challenge-wp.pdf
