A picture book written in C code
An illustrated story written in the C programming language (with English translations!)
This is a fun C programming book for beginners. It's unique because it's a story described with code! The code consists of simple full C programs that represent situations in the story. The illustrations next to the code show the situations. Also, the code is explained below each program.
I chose C because it’s a foundational language and the most popular language in embedded systems and microcontrollers. The programming concepts and C syntax are useful for beginners using the Arduino.
A Day in Code is available on Amazon: https://www.amazon.com/dp/B08LG7DW4C
Sam Myer wrote 10/09/2020 at 09:30 point
Hi, thanks for this material, I often use resources with such posts, books are my element, the easiest way is to understand from the review whether I should read this now, I also recommend you https://edusson.com/research-paper-writing-service a proven resource that I regularly use for my self-education, for the development of individual skills, you can also easily use the services of rating experts in the field of writing various materials, good luck!
[deleted]
Shari wrote 06/24/2020 at 17:52 point
Thank you so much! :)
