Interact
Physically interacting with the world can be extremely difficult for some. This project aims to make it a little easier.
Many years ago, watching my baby girl struggle with even the simplest tasks and joyfully celebrating great accomplishments that others would likely barely notice, I quickly realized the goal of nearly all of my future projects: 'To make the world easier to interact with'
With few exceptions, most toys on the market are too hard for someone like my daughter to interact with. Maybe it requires pinching a teddy bear's paw in just the right spot, grasping, or often pushing harder than is possible.
There is already an answer that works for a lot of people. Switches. There are commercial switches that can be purchased, and there are adaptive toys that can be purchased that work with the switches. There's even a standard interface (3.5mm phono plugs) so interoperability is not an issue.
But the answer is imperfect.
This project aims to identify and overcome those imperfections in order to vastly increase the ubiquity and impact that this technology can have.
Existing switch solutions
First, I'd like to look at the issues with existing switch solutions.
  • Switches are expensive.  A single basic adaptive switch can easily cost $50-$100. And it's not that these companies are greedy-- many are doing great work to bring forth innovative and life-changing solutions.  The economies of scale just aren't the same as for mass-market products.
  • Switches aren't very customizable.  Maybe you can change a picture or a color of a piece-- which truly is great.  But as a customer, you're not going to be able to redesign a shape, add a new texture, design a new fastener, etcetera.
  • Because the designs and manufacturing are done by a small set of individuals, using a manufacturing technology with high fixed costs (injection molding), the cycle of innovation is limited.
I plan on addressing these issues by designing 3D printable switches.  But there are a number of such switches that have already been designed and shared.  I've even made a few.  But there are common deficits for the designs currently available.
  • High force.  Many 3D switch designs require a relatively high amount of force to activate.  For some users this may not be an issue.  But for other users, it is critical that switches activate even with the most trivial amount of force.
  • "Play" in the activation surface.  It's difficult to design a switch with tight enough tolerances so that there isn't "play" or looseness in the top of the switch.
  • Large "throw" in the switch.  The switch should not require much travel before it activates.
  • Durability.  There's a lot of variability in designs in this department, but as far as I'm concerned durability is critical.  A quality switch needs to stand up to not only repeated intense use, but also to abuse of siblings to will drag it around and truly beat it up.
  • Size.  While there are switches of all sizes, that's not really what I'm getting at here.  Many 3D printed switch designs are much bigger and more clunky than they have to be.  A good switch design should only be about as big as the activation area of the switch, with any extra size kept to an absolute minimum.
  • Activation from the side.  Commercial switches generally excel at this while very few (if any) 3D printed designs seem to get this right.  Ideally, the whole side of a switch should be an activation surface.
  • "Feel" of the switch.  Commercial adaptive switches generally have a great feel.  This can probably be attributable largely to force, play, and throw.  But subjectively, the switch should just feel good.  On its own, it should be as engaging as a fidget spinner.
  • Equal force.  There should be no obvious spots on the switch that require noticeably more or less force for activation.
  • Sticking.  It's surprisingly hard to build a switch that doesn't ever stick.  But it's critical.  Switches are all about engaging with the world and autonomy.  And if they stick and require somebody to come fix it, then the switch has failed its job miserably.
  • Dead spots.  Similar to sticking, the switch needs to do its job every time without fail.  If there are ever situations when the switch is hit and it doesn't activate, it has absolutely failed.
  • Mounting.  Switches should be like swiss army knives in their mounting options.  You never know how you'll want to place something, and I don't think you can ever give too many options on how to get a switch mounted just the right way.
ButtonCap_Dots_Circles.STL
Standard Tesselated Geometry - 24.68 MB - 08/16/2020 at 17:34
Download
ButtonCap_Rings.STL
Standard Tesselated Geometry - 8.01 MB - 08/16/2020 at 17:34
Download
CapHolder_14.STL
Standard Tesselated Geometry - 3.09 MB - 08/16/2020 at 17:34
Download
ButtonCapBase13.STL
Standard Tesselated Geometry - 4.09 MB - 08/16/2020 at 17:34
Download
ButtonCapInsert_0.6mm.STL
Standard Tesselated Geometry - 252.72 kB - 08/16/2020 at 17:34
Download
View all 20 files
  • Missing Requirement
    Mike Turvey • 08/24/2020 at 08:22 • 0 comments
    I missed a critical requirement.  There's a lot of great assistive tech out there that works really well, but boy does it look clinical, boring, medical-- just not exciting.  Whatever I make here must be exciting and engaging.  Part of that is color-- with 3D printing, there's a rainbow of choices.  You can make switches with the colors of your favorite team.  You can pick vibrant colors that grab attention.  You could make a pile of different switches so you can always match the color of your shoes or the ribbons in your hair.
    We need switches with lots of different designs.  Different textures.  Different personality.
    Here's a selection of some of the designs in a variety of colors. All built on the same basic Interact Switch platform.
    I've created a bunch of different designs-- and others are free to make plenty more.  The sky is truly the limit.  Additionally, the varied textures are valuable for those with vision impairments-- or even just to provide a tactile association between a switch and its action.
    Simply-- these switches need to be fun.
  • The Dome
    Mike Turvey • 08/24/2020 at 08:12 • 0 comments
    One of my original requirements was that the switch be easily triggered by hitting it on the side.  While the existing flat switches do still work if you hit them on the side, it seems like we can do better.  If the switch cap is a dome, then any force hitting it on the side would still result in a downward force.  Here's my first iteration of such a design.
    This first attempt was a bit of a failure.  It is basically a hemisphere on top of the existing switch.  There are two main issues here.  First, there are still flat sides, and those aren't great.  The other issue was a bit of a surprise to me.  This design has a lot of infill, making the switch cap much heavier.  As a result, on rare occasions, the switch will stay depressed even when you stop pushing it.  From a usability standpoint, that's a huge problem.  Back to the drawing board.
    And here's the redesign:
    This fixes both issues with the "hemisphere" design above.  Most of this switch is just a 2mm thick shell, so there's little added weight.  And the design is smoothly curved, but even out to the edges there is a substantial slope, so it's exceptionally easy to depress, even with a completely lateral movement.
    I think it's also worth taking a moment to look back at the original goals.  There is no single switch that could ever be the one design that's best for everyone.  For example, the flat switch is a better design for using as a headrest-mounted switch because it's more comfortable to push than the dome.  But the dome is probably better when on a tray or table, as it requires less precision to activate. When identifying the right assistive technology for a given situation, you've got to be fluid with your assumptions and willing to try, fail and try again to find what will work best.  In that vein, this project is not trying to come up with "the perfect switch."  It doesn't exist.  What I hope to accomplish is to put out a set of different designs, for various affordable switches that will hopefully meet a the needs of a wide array of users and be equal or superior to what you can buy right now for a burdensome amount of money.
  • An Inside View
    Mike Turvey • 08/12/2020 at 20:14 • 0 comments
    It can be hard to visualize how the various parts come together to form a working switch.  I made the following mockup to help visualize how the precise interaction of the parts and troubleshoot issues.
    Here, you can see the Omron SS-3GP switch in its cradle (with no wires attached).  The black "cap holder" is screwed down to the red base.  It's easy here to see how the black "switch holder" keeps the green "switch cap" from falling off or rotating, but does so with minimal friction.  The green "switch cap" is missing its top, allowing us to see in.  And the pink "switch insert" inserts into three holes in the switch cap, and depresses the switch.
    We've discussed tolerances some before, and this picture makes it much easier to see how the design minimizes and mitigates the effects variation in part dimensions.
    In order for this switch to perform well, the height of the pink "switch insert" must be precisely controlled to within about 0.1mm to 0.2mm.  And we have to reliably hit that when some of these parts with layer heights of 0.2mm.
    Minimize Variations
    First, to minimize the variations, it's important to consider how a 3D printer manufactures a part.  First, it lays down an initial layer, generally smooshing that first layer into the print bed.  The print bed itself will also have slight variations.  Combined, this means that the first layer (or maybe even first few layers) of a part can be expected to have fairly high variation in thickness.
    Another place where you'll see a lot of variation is in overhangs.  There will be some drooping in overhangs, and the amount of drooping can vary with temperature, filament, printer, speed, cooling, support, etc.
    Where we can find reliable, precise tolerances is between horizontal "top" surfaces on a part.  Let's look at the "cap holder" for example.  It is printed upside down, and the critical dimension (where it mates with other parts) is on two "top" surfaces.
    With the red base, the critical dimension is on the top surface-- where the cap holder feed reside and where the SS-3GP microswitch sits.
    With the green "switch cap," the critical dimension is the top surface that mates with the cap holder, and the pockets that hold the pink "switch insert."  The pockets have both a "top" surface and an overhang.  The variance in the overhang is largely suppressed because of another trait of the overhangs: they're a bit soft and sponge-like.  The pink "switch insert" has a slight wedge to it, and the softer overhang helps to press the "switch insert" flush against the top surface of the pocket.
    That leaves the switch insert, which is also printed upside down.  That means that its top surface is being pushed against the top surface of the pocket on the green switch cap.  The other critical surface is where the "switch insert"  presses against the microswitch.  Again, this is a top surface when printed, and so has high precision.
    Of course, the last piece in all of this is the Omron SS-3GP switch itself.  And it's safe to say that all of its tolerances are significantly better than the 3D printed parts.
    Mitigate Variations
    Now that we've done all we can to minimize variations, we now have to accept the fact that nothing is perfect and we'll have some variation and have to handle it somehow.
    Early in the design process, I knew that I wanted the ability to have a small, quick-to-print component that would be easy to replace that could be used to "shim" to adjust for variations in tolerances.  That's where the "switch insert" comes from.  Each switch insert takes less than 10 minutes to print, can easily be swapped out, and can be printed with different thicknesses in 0.1mm increments.
    Above, you can see 4 different inserts, where...
  • Comparison
    Mike Turvey • 08/09/2020 at 06:28 • 0 comments
    I've been wanting to quantify the "feel" of a switch for a while now.  The best way I have been able to come up with it to measure the force vs. deflection curve.  In this update, I'll present the data for several different switches.
    The first switch tested is this Scallop Switch.  It's a large switch sold by the nonprofit American Printing House for the Blind.  It's a very functional switch at a price point that's unmatched. (They also have a great wobble switch that I also highly recommend.)
    The next switch I tested, I'm calling a "clunky" switch.  This is one of my early designs, and while it is functional, it just feels clunky to use.  I was really interested to see how this would compare to the other switches.
    Next up is the Specs Switch.  This is a popular small switch.  It has a short throw and is manufactured by Ablenet.
    We also have the Jelly Bean switch, also by Ablenet.  This is a very widely used, popular switch.  It's a great medium size and can be used in a lot of different situations.
    This next switch is not an adaptive switch at all, but rather it's a switch that makes one of various noises when hit.  They're sold in a pack of 4 for about $15.   I included it here because I see a lot of people converting this into an adaptive switch (you can find a bunch on Etsy, for example).
    And lastly, we have our new homemade switch.  To make it, all you need is a reasonable 3D printer and some very basic soldering skills.
    Let's take a look at the test rig.  Most of these switches activate over a pretty short throw.  In order to get a good idea of what the force vs. displacement graph looks like for each of them, we'll need to measure the force at sub-millimeter increments.  Fortunately, 3D printers are great such precise movements.
    I attached a short extension below the X axis that would depress the switch as the Z axis is lowered.  To avoid slipping, the block of wood that pushes on the switch is directly beneath the lower X axis rod.  (My first iteration lacked this piece, and I found that the clamp was not strong enough to keep the two other boards from shifting.)  I hooked this rig up to Cura in able to move in increments of 0.1mm.
    And now the results.  I've posted the same graph with both a linear and a log scale-- I think both are
    valuable to understand what's going on with these switches.  I've also marked each line with a point that indicates when the switch was actually triggered.
    Linear:
    Logarithmic:
    The force required to activate each switch is a hugely important factor in the use of these switches. From this, it's easy to see that the "Answer Buzzer" switch requires significantly more force to activate than any other switch.  Keeping in mind that the switch is supposed to make it easier to interact with things, I find that such a large force makes it a pretty poor option for adapting for most users.
    My favorite line to see here is for the Clunky Switch.  Wow!  It's all over the board, and not a smooth curve at all.  The negative slope from 2.5mm to 4mm was particularly interesting.  Even though the force to activate this switch is much lower, it's really not a good option.
    Of the remaining switches, it's worth noting that the force curve is in general very smooth.  The shallower the slope, the "softer" and more cushion the switch seems to provide.  I think this part of the curve after the switch has activated really plays a large role in the overall feel of the switch.  And matching the graph, of these 4 remaining switches, I'd definitely subjectively call the Specs switch the "hardest" and the Homemade switch the "softest."
  • Straining
    Mike Turvey • 08/03/2020 at 20:09 • 0 comments
    When I started switch adapting toys, I quickly found out that adding a working switch port is only half the battle.  It's got to be robust.  Siblings will take a switch adapted toy and ruthlessly drag it around by the switch cable.  So, I learned the importance of making things strong and "toddler proof."
    Here, you can see a couple of aspects that protect the switch from being tugged all about.  The obvious protection is the curving inside the switch with posts to keep the cable in place.  It dissipates even a strong tug on the cable.  I'm still a little concerned about the long term protection this will provide with repeated tugging.  If that becomes an issue, it may be necessary to place a glob of hot glue around the wire at the base of the switch.  So far, I haven't seen any failures here, so we'll see.
    The other protection is more subtle.  Another failure mode is where the wire goes into the switch.  With prolonged use, this point will flex repeatedly and the copper wires can break inside of the sheathing.  That's why you see strain reliefs on so many cables-- basically to spread that bend over a larger area.  But there's no good way that I'm aware of to add a traditional strain relief here using traditional 3d printing without adding undue complexity.  (I'm sure something could be done with TPU, for example, but keeping this easy to manufacture with materials just about anyone would have is a priority of mine).  So, instead, I molded a U channel that the wire sits in.  This resists the bending, and the resistance increases as the wire gets closer to the entrance hole.  The intent is spread the force of a bend over a longer area, as flexing of the wire laterally requires it to be pulled up and out of the U channel.  I'm curious to see how this works long term-- crossing my fingers.
  • Addin pictures
    Mike Turvey • 08/03/2020 at 19:38 • 4 comments
    Somehow several pictures from my last log entry didn't show up after I posted it.  I don't see a way to edit it right now, so I'm posting them here.
    This is the button, once assembled:
    For assembling the cap, first the cap insert goes in the cap:
    Next, the Cap holder clips in:
    The switch is mounted in the base with the wire soldered on, and then the piece above is screwed down (I'll post more pics later of this part of construction-- I don't have any right now).  The cap insert is what pushes on the microswitch's button.  And the cap holder is the piece that keeps the cap from pulling up/ falling off.
  • Effective Button
    Mike Turvey • 08/03/2020 at 16:04 • 3 comments
    After dozens of revisions, I've got a button that I feel is getting pretty close to meeting all the requirements.  Here it is:
    It's rather unassuming, but it is a highly reliable switch and takes only ~60g of force, with a uniformity of activation pressure across the top surface.  Mechanically, this seems a really good solution.
    Here is a breakout of the various components:
    And here's a picture of the cap holder, and cap insert placed in the cap before being screwed down to the base:
    And with the cap holder in place:
    A key aspect to the "feel" of the switch is that when in its resting (non-pushed) state, the microswitch is already under some pressure, although not activated.  If you don't do this, the switch will feel "sloppy" and rattles around. I found this to be tough to achieve consistently and reliably because it requires component precisions that near the layer thickness of the 3d printer (empirically, somewhere in the neighborhood of ~0.1mm).
  • Captor: Innie or Outie?
    Mike Turvey • 08/01/2020 at 19:45 • 0 comments
    This is one of my early switch designs.  I think it's a fairly typical representation of many of the 3d printed adaptive switch designs I've seen.  There's a big plunger on top, and it's held captive by a ring around the outside.  And that ring is attached to the base somehow (in this case, it's cemented together).  Inside, there is a microswitch, with the phono plug attached in a NO (normally open) configuration.  It is functional, but it's pretty clunky, requires more force to activate than is desirable (it's ~ 150g ), and really doesn't have a great "feel" to it.  At some point, I'd like to graph the force vs deflection.  I think this would really help to quantify what I right now see as the "feel" of the switch.
    The biggest distinction I've seen between commercial switches and 3d printed homemade ones is how the button is captured.  As in the design above, 3d printed switches use a capture mechanism on the outside of the button, like this:
    This design generally means that half of the height (or more) is really this ridge that isn't an activation surface.  It means that there is a ring around the whole switch that basically "protects" the switch from being activated. When the whole point of these switches is to make it easier for someone to interact with the world, that's a big design flaw.
    And that's why most of the commercial switches I've seen move the capture mechanism inside:
    You can see an example of this design here:
View all 8 project logs
View all instructions
Billfred Leverette wrote 02/28/2022 at 16:04 • point
Mike,I work with the state AT Act program here in South Carolina, and after warming up our new Prusa with some basic prints I went ahead and fired off one of your switches (well, the printed parts anyway).  My director is in love, and we've got parts and filament for about 100 on order now.  Which is huge compared to the homemade switches we've made in the past...but it also means I have to print 100 switches on a single MK3S+.
I recognize this only will apply to the caps and maybe the bases, but have you (or others) tried pushing the nozzle size bigger on these prints?  We've got the nozzles to try it ourselves, but I figured I'd fling the question out there on the off chance you knew.  Looking forward to getting some assembled ones out into the community!
Mike Turvey wrote 04/25/2023 at 22:17 • point
Hi Billfred-- I see my reply is really delayed-- how did the switch build go?  Did you end up using a larger nozzle?  That isn't something I've done, but I have made most of the switches I've done using an MK3S.  The parts that give me the biggest headache are the cap holders and the switch caps, both because of the overhangs.  I am working on a new version of the switch design that does away with any major overhangs that cause prints to fail.   Sorry for the really late response.  I'd be interested to hear how your experience has gone.
Simon Merrett wrote 06/14/2020 at 07:03 • point
Hi Mike, thanks for sharing your investigations and perhaps designs with us. I have recently been prototyping an accessible remote control for a person who suffered a brain injury and needs to control eg lights around their home.
I started with menu scrolling using the commonly available PlayStation style analogue joysticks but the user asked for a separate switch than the centre-press on the joystick for option selection. So the second prototype has a Kailh box blue keyboard switch in it. Although this would probably fail your requirement for short travel, it is a satisfying action. I was stuck on how to add a custom key cap to the Kailh switch but I found that 0.1" dual row header pins fit nicely in the "box" when rotated 45 degrees. My button form was made from hot glue, melted with the hot air gun in a silicone "crucible". I'll post a link to photos if it's of interest.
In terms of your review, you may find this thread on the Arduboy forums interesting as you can see a discussion of what switches feel like and how reliable people find them in homemade, handheld games consoles. https://community.arduboy.com/t/what-are-the-best-tactile-buttons-for-homemade/8903
One thought that occurred to me is that you could look at the range of "diy touch probe for cnc" results that come back with things like https://www.instructables.com/id/CNC-Manual-Touch-Probe/
These mechanisms, probably inverted for a push switch, would be a good start for short travel, edge triggering and consistent feeling switching, IMHO.
Mike Turvey wrote 06/14/2020 at 23:31 • point
Hi Simon, I appreciate the pointers.  I've ordered a few of the Kaih switches from Aliexpress to try out.  It looks like they have just over 1mm of pretravel before the switch activates and only require a trivial 10g of force to activate.  I don't see the pretravel as a problem, as I've learned that all of the best commercial adaptive switches are build so that the mechanical switch is always a somewhat precharged.  From past designs I've worked on, I think this gives the overall button a more responsive feel and eliminates any "loose" feel of the switch.  I'd never thought about CNC touch probes as being analogous to this problem, but you're right-- it's a very similar problem, and a good source of inspiration.
I actually started this project this past winter-- it's bothered me for a long time that there aren't any 3D printable pushbutton switch designs that are as good (or hopefully better) than the commercial designs.  In part, it's been a challenge to myself to see if it's possible.  I'm pretty far down the prototyping path already and I'm very happy with what is possible. I need to put some time into updating this documentation to get it to where I'm at now.
Simon Merrett wrote 06/15/2020 at 08:15 • point
OK, I know that kind of project - mature but undocumented!
As you bought the Kailh switches, here are some photos of how I attached a custom silicone dome cap to my prototype: https://photos.app.goo.gl/QKFracSMXmMhxpSb9
Note that in one of the photos I found that 2x M2.5 screws on diagonals might also make a handy cap attachment method.
