After dozens of revisions, I've got a button that I feel is getting pretty close to meeting all the requirements. Here it is:
It's rather unassuming, but it is a highly reliable switch and takes only ~60g of force, with a uniformity of activation pressure across the top surface. Mechanically, this seems a really good solution.
Here is a breakout of the various components:
And here's a picture of the cap holder, and cap insert placed in the cap before being screwed down to the base:
And with the cap holder in place:
A key aspect to the "feel" of the switch is that when in its resting (non-pushed) state, the microswitch is already under some pressure, although not activated. If you don't do this, the switch will feel "sloppy" and rattles around. I found this to be tough to achieve consistently and reliably because it requires component precisions that near the layer thickness of the 3d printer (empirically, somewhere in the neighborhood of ~0.1mm).
It's intriguing - please would you share more pictures of e.g. the inside of the cap or partially assembled so the principle of operation is apparent?
Sorry about that. There were supposed to be more pictures in this log that appear to have been dropped when I posted it. I don't see a way to edit the log above, so I just posted a new one with pictures attached. And definitely more to come. This has been a really interesting project for me-- the tolerances ended up being a lot tighter than I expected. That said, I've been impressed at what a 3D printer can reliably spit out.
Ok, I think there should be an edit button near the log title. Thanks! I wonder which parts of the tolerances are most critical and whether continued design refinement could remove some dependence on material or process tolerance. For example, if it's the height of a part that is critical, can it be made from sheet stock of that thickness to start with? Not a suggestion but an illustration of what I mean. Looking forward to more logs too.
