Even though the first rev boards have been sent off to SeedStudio, I thought I'd re-read through the PQ60 documentation that one of the fellow enthusiasts had created. Turns out I've missed a few connections between the bottom connector and the top one. It won't affect basic testing, but if the design gets used in a flight version, I definitely need to make some changes!
Other things in progress are the creation of an adapter board for a 3.3v Arduino Pro Mini. This will map the arduino pins to the backplane, and provide limited power to the 3.3V bus. Not enough to power the radio by itself, but I might include a higher capacity regulator and a DC Jack input. Or USB input. Space will dictate some of these things!
