4th of July project, assemble the DJI F550 ARF
07/04/2020 at 23:29 • 0 commentsOK so I know I cannot do it all today , but I cant help but get it built right away and I already see places I could reduce weight. Pictures will be added shortly
We have a 3450 Watt base station generator
07/04/2020 at 22:08 • 0 commentsHere is my base station generator which I believe I purchased for 349 with the gas tanks. It is 3450 running watts with 4500 surge watts. This is on a 110v circuit with a 30 amp circuit breaker. Doing some math the "real" wattage is more like 3300 watts until there is a risk of popping a circuit breaker. This is well within what we need, Honestly in a pinch a 2000 watt tiny generator would work, but having a big pad for additional equipment connected like lights, computer, amplifier etc. is very useful for the project. I actually used this a few days when a tornado came through and knocked out power for nearly 2 weeks. Overall is it just a couple inches bigger than a couple 5 gallon gas cans and even fits in my trunk of my Rav 4 without laying down the seats with both gas cans and more.
On a side note, I really need to spread some grass seed outside for these bare spots. I have a shameless electric car plug in the background, that's a Mitsubishi Imiev.
Shipping update on the DJI F550 airframe
07/02/2020 at 23:03 • 0 comments -
Bought a Donor Air Frame
07/02/2020 at 01:39 • 0 commentsI had a few challenges in the selection. The first issue is that there is so much junk equipment that under performs the specifications. I wanted to use something fairly easy to find and cost effective. There are lots of clones for the DJI F550 Flame Wheel, but many of the options were china direct and could not promise to arrive soon. There were clone kits avail for around 250 dollars, but checking further I found a couple of genuine DJI F550 Flame Wheel ARF ( almost ready to fly) kits that included the ESC motor controllers , the motors and the props as well. The price was.... $200 .... SOLD! Well that was fun, I asked the seller to send pictures of the contents in all their glory :p
Now we wait for it to get here.
Idea Conception
07/01/2020 at 23:25 • 0 commentsBefore I start, for the record, I despise the word drone being used to describe a multi copter. It gives them a negative reputation as drones are the workers and defenders of bees and wasps and that gives off a negative reaction in our lizard brain in the back of our minds. So there I said it. I will probably still refer to it as a drone however because that is what most people call them now as that is what they have been labeled by the media starting a few years back. Thanks Fox news :\
I have been wanting to do this project for the last couple years, as a matter of fact since the 2018 Hackaday Super Conference. I needed a way to lift an AP up into the air for extended times to control robotic projects like rovers, lawn mowers and such. Long range mostly unobstructed high speed internet access. This way I can collect data in real time and HD video from several cameras. That is how this project was born. I realized it could not only be used as a fast way to get a long range Wifi AP high enough to use , but other options too. To be useful the multi-copter needs to have an extended flight time, hours if needed without coming down. I came to the conclusion it needs a power cord tether coming from a generator or other power source on the ground. Given that the multi-copter will already have a wire tether, I realized it could potentially lift other things too. The next idea in the concept was getting either ethernet or fiber optic cable up to the multi-copter, fiber optic cable is much lighter than ethernet over a long length, so if I can get that to work that is ideal. but I will ether need a AP that is light and takes fiber or some kind of fiber to ethernet adapter.
I started researching if this has ever been done before, I did find a couple of groups that did it so they could fly their quad copter demonstrations at shows all day without swapping batteries. They did that by using high voltage , 600 volts I believe I remember and stepped it down on the quad copter frame and it drug around about 20 foot of extension cord. It didn't look like anything special and it was certainly thrown together for this one purpose, and a temporary solution for shows for their product demonstration. Now that I knew it was possible, I really started digging into types of wire I could use to be lighter and other solutions to make this a overall better system.
