end_effector.STL
The end effector mount.
Standard Tesselated Geometry -
433.48 kB -
06/25/2020 at 16:39
Download
forearm_mount_motor.STL
This is used to mount the small actuator.
329.87 kB -
06/25/2020 at 16:38
Download
shoulder.STL
This is used to connect the links for the large actuators.
325.08 kB -
06/25/2020 at 16:37
Download
connector_wires.STL
These are the connector links (print 2).
142.66 kB -
06/25/2020 at 16:37
Download
shoulder_mount_motor.STL
This is the mount for joint 3.
459.55 kB -
06/25/2020 at 16:36
Download
base_holder.STL
This holds the actuator for joint 2.
591.68 kB -
06/25/2020 at 16:36
Download
base.STL
The base that mounts to the ground plane, and mounts the actuator for joint 1.
418.05 kB -
06/25/2020 at 16:36
Download
