For my final PCB, I went on ALPS SKRRABE010 switches which I'm really fan of the feeling. For the D-Pad, I wanted to use an ALPS SKRHAAE010 multi-directional switch also for the feeling it provides. It reminds me of the NeoGeo Pocket Color which is a console that I particularly liked for this point.
Here is the rendering of the PCB after routing:
Once this part was completed, it was therefore necessary to wait for the PCB to be received. However, the modeling of the case could begin. The first thing to do was to make the PCB in Fusion 360 from the images above.
