Finished tested all the hardware interface with the TTGO t-display board, and send the pcb to manufacture.
Now I start to develop the code to interface with de Lidar. To help coding I solder a simple board to interface the Lidar with ttgo, tested the pwm which works fines, for next few days I will work on implementing the protocol for the lidar.
Leandro
