For 3.5mm headphone jack, use the following.
The terminals below are for the tip, ring 1, ring 2 and sleeve structure.
Two terminals are located on Ring 2, so it can be used regardless of 3-pole or 4-pole.
For the GBA SP bottom shell, just make the space between the battery terminal and the battery latch as above.
bangooh
Lucas Rangit MAGASWERAN
AirCruiser
microcontrollerprog
Great work, I appreciate your efforts for the all work and images you shared.
Regards,
My Boy APK
