LIDAR Compass: Laser Safety
09/03/2020 at 14:49 • 4 commentsThe LIDAR Compass fires two separate lasers in a bunch of directions, which calls to mind some concerns about eye safety. How do we make sure that, in the course of normal operation, we don't accidentally blind anyone?
You'd be right to guess that a safe bet here is to just use a low-powered run of the mill red laser diode. Unfortunately, red isn't, in my testing, especially visible after getting flung around and spread into a big circle by the spinning mirror. Green would be a much better option.
Green laser modules are very cheap and plentiful, but it's VERY hard to get modules that actually do what they claim. The "laser enthusiast market" being the primary consumer of such modules, most that you can find output WAY higher power than they say, and also omit other safety precautions that add up to extreme non-eye-safety. In particular, the ultra-common and high-brightness 532nm green lasers all over the internet are DPSS - diode-pumped solid state. In this topology, an 808nm laser diode fires at one crystal that absorbs the 808 and re-emits 1064nm light, which then hits a second crystal that frequency-doubles that to 532nm. Because each of those two stages is relatively inefficient (something like 20-30% end to end), there's a ton of leftover 808nm and 1064nm laser light coming out the front of such lasers, and when they're built down to a price, they often lack the optical IR-cut filter to remove those frequencies.
Making matters (much) worse, when those crystals are too cold, they no longer work. So if the device overall is too cold, it'll appear off, while outputting still-blinding invisible IR laser light.
The solution we've settled on to get around these concerns is to simply pay a little more for a diode that 1) operates at 520nm, with a direct-emission source (no invisible byproducts), and 2) at the power level it claims of <1mW.
Luckily, this still produces a bright-green dot that should be visible even outdoors on a job site. -
LIDAR Compass: Rotor Position Measurement and Feedback Laser Update
08/19/2020 at 20:36 • 0 commentsA very key aspect of the LIDAR compass is a live visual feedback system using a laser to point out all the positions where the structure is in-spec, so builders can make sure they lay bag in the right spot as they go. This visual feedback system requires a couple of key elements:
- A (visible) laser to show where placement is correct
- A means of turning that laser on and off while rotating it through the cross-section of the dome
- Pursuant to (2), a means of measuring the LIDAR scan head position
(1, 2) are easy - lasers are cheap and low-power, so it should be no trouble to turn one on and off with just a microcontroller pin. Maybe a transistor, if that's not enough current.
(3) is where the real fun lies: a reliable sensor to measure the scan head rotor position that we'll be piggybacking on, and code to handle that sensor appropriately. That's what this update is really about.
Putting the pieces together
The last LIDAR Compass update showed a proof-of-concept optical sensor that seemed to do a good job measuring a white dot on the edge of the rotor, and pulsing every time it went by. This update builds on that success, using that sensor and a physical assembly to build the entire chain, from figuring out where the scan head is in its rotation to pulsing the laser for set angular duration.
Lidar Physical Design Update
08/18/2020 at 02:26 • 0 comments -
LIDAR Compass: Rotor Postion Sensing
08/16/2020 at 22:01 • 0 commentsA key feature of the LIDAR Compass concept is a visible laser firing out in the same plane as the sensor to indicate where measurements were taken that fall in-spec of the design. A key enabling factor of such a scheme is that the LIDAR already has a rotating scan head that we can easily piggy-back on for aiming the feedback laser. This does require, however, that we KNOW the precise position of the rotor head at all times, so we can know whether to enable or disable the feedback laser.
Sensing Rotational Position
There are a couple ways to do this:
- Hall effect sensor
- Magnetometer
- Optical tachometer
In the case of the hall effect sensor scheme, a magnet on the edge of the rotor passes by a hall effect sensor, which measures magnetic force. Whenever the magnet passes, the sensor outputs a pulse, which is read by a microcontroller. The period between pulses gives the average rotational speed over the last full rotation. After timing out a few such rotations, the microcontroller can infer the rotor's position at any time by calculating the solution to (angular position/360)=(time since last pulse/average period). Sensored brushless DC motors use a scheme like this, with a hall sensor at every pole to tell the motor controller when to commutate.
The magnetometer measurement similarly uses a magnet, but instead of a normal axially-magnetized magnet that pulses a sensor when it goes by, you place a diametrically-magnetized magnet right over the axis of rotation, and put an electronic compass right over that. This is a bit like rotating a bar magnet above a compass: the compass always points in the exact direction the bar magnet is facing at any given time, allowing you to read the rotor position directly. This is a relatively expensive way to do things, and requires having access to place a sensor right along the axis of rotation, so it's relatively uncommon. However, I wouldn't be too surprised if this is how the RPLIDAR A1 itself operates, given the need to know angular displacement precisely.
The optical tachometer scheme is spiritually exactly the same as the hall sensor scheme, but instead of using a magnet and a magnetic field sensor, you use a reflector and a light sensor. The biggest advantage of this scheme is that you don't have to put a heavy magnet on the precisely-balanced LIDAR rotor; a dot of paint will do.
Implementing the Optical Tachometer
Advantageously, a sensor that looks a LOT like this is pretty common in DIY robots. Since infrared LEDs and photodiodes are both quite cheap, cheap toy robots very often use simple reflectance sensors based on these parts for obstacle detection. An LED lights up the scene, and if the photodiode sees enough reflected infrared light, the sensor triggers, assuming a nearby object is reflecting that light.
The sensor pictured above, $9 on Amazon for 5, includes a dual op amp and a trim pot to let you set the sensitivity, and to threshold the measurement into a digital "obstacle/no obstacle" output. That happens to be almost everything we need to make an optical tachometer: the only additional item we need is a "snoot" or shroud to direct the infrared light at our paint dot on the rotor, and make sure the receiver photodiode ONLY sees light reflected from that dot. A simple job for a 3D printer:
This feels almost too easy at this point, but it's worth pointing out here one gotcha of this idea: plastics are very often transparent or near-transparent to infrared, especially acrylates, even when colored. It's very possible that this snoot doesn't work well enough to block other sources of reflectivity without an additional coat of paint or something. But let's go ahead and try it anyway (printed in black PETG). We'll be looking to measure the white paint dot on the rotor below. Note that it isn't really critical WHERE the dot is placed, as long as it's not the same plane as the measurement laser so our sensor for it won't block the measurement. We'll have to calibrate this after the fact anyway, since it's unlikely the edge of the sensor pulse precisely lines up with any exact geometry of the dot. More likely, some "amount" of dot comes into view before the sensor reads high enough to trigger a pulse, and getting that alignment repeatable between units with a trim pot probably won't ever happen anyway.
As it happens it WAS Just this easy: the snoot works great, the sensor only reacts to reflective objects directly in front of it, and the dot does a perfect job creating a high contrast between rotor (off) and dot (on):
Using basic measurements on the scope, I was able to determine a period between pulses of 123ms, for a rotational frequency of about 8.13Hz, given a motor voltage of 5V as the unit comes stock powered by USB. And of course, if I put a finger on the rotor to slow it down, we can see that too.
So it looks like the physical housing to hold this sensor in the right spot is going to take a lot more design effort than the sensor itself, which is exactly what we like to hear!
Working Prototype 1- Pipe Compass
08/14/2020 at 15:57 • 0 commentsA Living room simulation of Cal Earth construction site.
In order to test the prototype, pillows were used to represent each layer of super adobe bag.
Due to travel restriction and limited access to experiential ground space the testing of the prototype was adapted in Barcelona, Spain.
Working Prototype Parts
The moving post is indicating the correct position of the super adobe bag.
The laser measuring the distance for the reference of the site handler.
User Manual.
Step 1: Preparation of site - Make a firm/ stable base holder.
Step 2: Insert the vertical post into the base holder.
Step 3: Clamp the Joint to the vertical post.
Step 4: Insert the moving post into the joint.
Step 5: Refer to your construction diagram/ Cal Earth app to get the accurate measurement for the next layer of the super adobe bag. Measurement from the center of the Vertical post to the center of the super adobe bag.
Step 6: Place the Super adobe bag and start filling it with composite mixture, fill the bag completely. Remember not to complete the ramming of the super adobe bag.
Step 7: Click the measure button on the Joint, Check the displayed measurement on the LCD screen.
Step 8: Adjust the super adobe bag as you are ramming it in place in order to match the display measure with desired measurement from the construction drawings.
Step 9: Use the moving post to touch the center of the rammed super adobe bag to cross-check the correct measurement.
Step 10: Un-clamp the joint and move it along the vertical post for the next layer of super adobe bag.
Continue the same process until you complete all the super adobe layers.
Earth Funnel Proof of Concept
08/11/2020 at 21:19 • 0 commentsThe video shows the first test of the earth funnel to fill a 3m Superadobe bag. It feels easy to use, is light and allows the user to move and position the Superadobe bag with one hand and load earth using the other hand. The first 0.5 meters the weight of the bag is not enough to pull the bag off of the funnel so you have to do it by hand but after that it has enough weight to anchor itself so you can just slide the funnel along and it lays the bag for you.
Next steps for future development based on first test:
- Add 4 handles
- Secure the rubber band better to stop it sliding off occasionally
- Tighten
- 2-4 Extra band bands to hold this one on place (tangent to the circumference band)
- Make tube smaller but keep out ring the same size so the distance between the two diameters is wider.
- Flat lip on edge of larger funnel to put your feet on to hold flat to the ground when you are loading the tube
- Instructions to explain how to use
- Fully load tube before sliding.
- Make from final material (Sheet of recycled plastic)
- Make larger funnel smaller to reduce awkwardness
- Add a groove or a guide so bag lays in the right potion
LIDAR Compass Milestone: Verify a rectangular room
08/11/2020 at 18:35 • 0 commentsHere's the next milestone for the LIDAR compass: verifying that my office is "correct" given the static measurements I made with a laser tape measure of 2.663m floor to ceiling, and 3.901m wall to wall.
It turns out, the office is NOT "correct" - the ceiling slopes up a little from the outer wall of the house to the center, which is actually captured in the LIDAR feedback by the top-left corner being out of spec. For this test, I actually relaxed the pass/fail criteria to +/- 5cm instead of 2cm. Note: this isn't 5cm orthogonal to the wall, it's radial to the LIDAR. So a 5cm error where the wall is perpendicular to the laser radius is huge, whereas 5cm in the corners might not be much wall displacement from "straight" at all.
At this point, a significant source of error may be that the program "bins" LIDAR samples into the closest whole-degree, then just assumes the distance measured is EXACTLY that angle. Again - when the sampling laser is normal to the wall, this doesn't make much difference. But in the corners where the laser hits the wall at a steep angle, a slight angular misalignment will result in a more substantially erroneous radius.
I theorize that this angular-rounding is why there are almost no "out of spec" points in the middle of each wall, but some points are "bad" in the corners even when further-displaced points are "correct" again. The binning scheme is effectively introducing noise to the radius measurements.
For now, I have no intention to rework the code and correct this issue, as it involves substantial complexity and isn't yet critical. Eventually, I'd like to move to a system of, instead of storing 360 samples, one for each "degree" and each with some discrete angular error, storing a list of "all samples from the last 5 sweeps" including all of the actual angles at which they were taken. This sacrifices the convenience of being able to pick out angles from their position in the list, but should add almost arbitrary angular resolution, which we may eventually need to get better feedback laser performance.Note: The code corresponding to this milestone is in the Git repo as lidar_mpl_blit.py, at tag rectanguar-room-milestone https://github.com/alexwhittemore/CalEarth-LIDAR-Compass/blob/rectangular-room-milestone/lidar_mpl_blit.py
LIDAR Compass: Live Feedback
08/10/2020 at 22:33 • 0 commentsLast week, I showed the LIDAR system "verifying" a straight wall by printing out 1s and 0s to a terminal, to denote whether the distance measurement at that angle was "correct" to within +/- 2cm for a straight wall orthogonal to the 0* line from the LIDAR.
This is that same test, but running with a live visualization I put together using Python and Matplotlib. Blue-colored points are the "correct" distance assuming the infinite wall, while red points are "incorrect." You can see that as I rotate the LIDAR, the wall drifts in and out of "correctness." as more or fewer points fall within the +/- 2cm tolerance.
It turns out, it's PRETTY hard to repeatedly update a Matplotlib plot in a performant way that doesn't take a ton of processing time away from your main run loop. Most of the effort to achieve this was fixing performance issues with mpl.
It may not seem like much (it doesn't to me), but this represents SIGNIFICANT effort towards the end-goal of live pass/fail feedback via laser.
I'll try to post code publicly ASAP.
LIDAR Compass Milestone 1
08/07/2020 at 22:04 • 1 commentMilestone 1 isn't fundamentally complex, but here's some proof that it works! Most of the effort spent on this milestone actually went into discovery and experimentation with things beyond the milestone goal, like figuring out data formats and available information, how the LIDAR device works in practice, and so on.
Have a look at it working to profile a straight wall below:
LIDAR Compass Project Plan
08/07/2020 at 18:36 • 1 commentOne of the most important strategies for actually getting complex work accomplished is to break the complex goals down into more tractable, bite-size problems that can be checked off a list in-order, and that build up to the complex finishing point. It can be easy to see designs from an overly-simplified 10,000-foot view and think, "oh yeah, for sure I can accomplish that by then!" And you may well even be right about that - I think that's true for this LIDAR design concept. The very beauty of it is that most of the complexity is available off-the-shelf, and the end-use can be boiled down in features to a fundamentally very basic proof of concept.
But thinking like that still obscures the actual effort that's required to accomplish the end goal, and adds the mental overhead of having to figure out which piece to bite off next. Thus, without further ado, and arguably later than we should have gotten around to it, I present you with a list of LIDAR Compass milestones and scheduled completion dates:
Vertical wall verifier POC.
8/7/2020 (That's today!)
A simple iteration of the device that measures the distance to a vertical wall at 0° then verifies via on-screen feedback that the next few measured points are, indeed, on that same wall (plus shows their error). This is a very simple test case that, more than anything, proves I still know how to do basic trigonometry. If the POC works, it will basically light up a table of values in Python with "OK!" when the device is oriented perpendicular to a nearby wall, and those values will fall out of "OK" if the device angle changes at all. This will also start giving us a good idea of how much distance error there is in the LIDAR points, given that the walls of my house can be verified straight.
This milestone is due today, and isn't actually done YET, but work is going smoothly and at this point I'm spending more time on nice-to-haves and future work than on just knocking out the milestone itself.
Normal room verifier POC
8/10/2020
Same as above, but instead of only assuming one infinite wall, takes a model of an actual square room and verifies all points in 360* based on that. Assume a fixed distance from the ground, and fixed observation angle relative to the room. This isn't a huge step on top of the first milestone, which is why it's so close in time. But it is a big step in usefulness of the system, and sets us up nicely for the next milestone.
Laser feedback POC
8/14/2020
Builds on the above POCs to include visible-laser projection of go/no go onto wall. This is probably the biggest individual step of the project, and it might be ambitious to get it accomplished in only one calendar week. In theory, it's as simple as anything else, but in practice, it's the one piece of system integration where there's no prior-art, and it's where all the unknowns lie. For instance, the laser pulsing system may need to be independent from the Raspberry Pi running the show for reasons of time-stability, since the Pi processing and GPIO is hardly real-time. It may be possible to get the rotation synchronization signal for the LIDAR rotor directly from the LIDAR itself, but again, real-time constraints may not be sufficient in practice, and we're not even sure if the T0 of rotation is even available in software. This may require adding an external hall sensor to measure and time rotor movement, which isn't fundamentally complicated but IS a significant addition to the project scope. And so on.
Self-contained POC
8/21/2020
All of the above, running independently on a raspberry pi with some kind of remote login. In fact, we'll probably already get to this point by necessity as of the previous milestone. But one thing we haven't talked about yet is ingesting arbitrary geometry to profile in the form of a 2D DXF, and this milestone will contain that deliverable as well. This may well be a zero-effort step in terms of hardware, but once again DXF processing is, in my opinion, where the real software unknowns come in.
Final delivery
8/30/2020
A self-contained LIDAR system that can be administered with a phone. In theory, everything will have been "done" by the last milestone. In practice, we have to assume that there will be a level of polish and presentability the previous milestone doesn't yet incorporate, so this is how we capture that in schedule.
Does this seem a bit ambitious? On paper, in my eyes, no. But everyone has a plan until they get punched in the face, and I'm no different :)
