This log describes the recommended assembly instructions for the Buoy B V1.0 PCB. The following image shows all the required components, with an identification number that will be used in the log.
![](https://cdn.hackaday.io/images/5757761600213900352.jpg)
Components List:
- ESP32-DEVKITC-32D
- TB6612FNG MOTOR DRIVER BOARD
- CONN HDR 19POS 0.1 TIN PCB
- CONN HDR 9POS 0.1 GOLD PCB
- CONN HDR 8POS 0.1 TIN PCB
- Buoy B V1.0
- TERM BLK 2P SIDE ENT 5.08MM PCB
- TERM BLK 3P SIDE ENT 5.08MM PCB
- CONN HDR 6POS 0.1 TIN PCB
- CONN HDR 5POS 0.1 GOLD PCB
- CONN HEADER VERT 3POS 2.54MM
- CONN HEADER R/A 3POS 2.5MM
- Coin cell holder (included in Adafruit Ultimate GPS)
- Adafruit Ultimate GPS
- CONN HDR 16POS 0.1 TIN PCB (included in Adafruit Ultimate GPS)
- RFM95W LoRa Radio
- CONN HEADER VERT 16POS 2.54MM (included in RFM95W LoRa Radio)
It is possible to solder the components in many different orders, I'll describe the one that I followed, it can used as a reference.
Instructions
a.Solder the female headers 3 and 9 used to connect the ESP32-DEVKITC-32D to Buoy B V1.0.
![](https://cdn.hackaday.io/images/790071600214049541.jpg)
Once the female headers are soldered, the ESP32-DEVKITC-32D connects to Buoy B V1.0 through the headers.
![](https://cdn.hackaday.io/images/5461841600214141158.jpg)
b.Solder the female headers 6 and 7 used to connect the TB6612FNG MOTOR DRIVER BOARD to Buoy B V1.0.
![](https://cdn.hackaday.io/images/1820971600214266917.jpg)
The TB6612FNG MOTOR DRIVER connects to Buoy B V1.0 using the headers.
![](https://cdn.hackaday.io/images/2311751600214353600.jpg)
c. Solder the female header 13 to Buoy B V1.0.
![](https://cdn.hackaday.io/images/649171600214448908.jpg)
d. Solder the 3POS Horizontal JST-XH connector (17).
![](https://cdn.hackaday.io/images/4659651600214585466.jpg)
e. Solder the male header 15.
![](https://cdn.hackaday.io/images/7488521600214704812.jpg)
f. Solder the female headers 5 and 14 used to connect the RFM95W LoRa Radio to Buoy B V1.0.
![](https://cdn.hackaday.io/images/3173611600214818992.jpg)
g. Solder the male headers 22 to the RFM95W LoRa Radio. To do that it is necessary to cut a CONN HEADER VERT 9POS 2.54MM and a CONN HEADER VERT 5POS 2.54MM from the component 22. The RFM95W LoRa Radio connects to Buoy B V1.0 through the headers.
![](https://cdn.hackaday.io/images/5409421600214938669.jpg)
h. Solder the female headers 4, used to connect the Adafruit Ultimate GPS to Buoy B V1.0. Solder the male headers 20 to the Adafruit Ultimate GPS. To do that it is necessary to cut a CONN HEADER VERT 9POS 2.54MM the component 20. The Adafruit Ultimate GPS connects to Buoy B V1.0 through the headers.
![](https://cdn.hackaday.io/images/3175391600215077323.jpg)
i. Solder the male connector 16 to Buoy B V1.0.
![](https://cdn.hackaday.io/images/2706681600215200430.jpg)
j. Solder the terminal blocks 10, 11 and 12 to Buoy B V1.0.
Front Layer and Back Layer
The modules connected to the front layer of Buoy B V1.0 are the ESP32-DEVKITC-32D and the TB6612FNG MOTOR DRIVER BOARD.
![](https://cdn.hackaday.io/images/7786721600215569718.jpg)
The modules connected to the back layer of Buoy B V1.0 are the Adafruit Ultimate GPS and the RFM95W LoRa Radio.
![](https://cdn.hackaday.io/images/1620111600221320588.jpg)
