1Construction:
Needing 12 and 5 Volt power the SFF has only SATA power cables and of course I don’t have any SATA sockets. But I do have a junked laptop drive and cut out the SATA socket. The PCB is so thin ordinary scissors works here. This hacked socket is epoxied to the perfboard, and the rest of the components are hand-wired.
![donor PCB donor PCB]()
donor PCB ![]()
![needs moar trimming needs moar trimming]()
needs moar trimming This perfboard is zip-tied into an old ear-bud case, ready to be stuffed inside the computer.
The IR sensor has a little piece of heat-shrink over the IR LED, this keeps down light reflections inside the computer case. The sensor perfboard attaches to a strong magnet with a piece of steel wire (a paperclip will do.)
![ready for a Tiny chip ready for a Tiny chip]()
ready for a Tiny chip The Fan-Tach-shtick sits in an unused drive bay.
Randy Elwin
