Unlocking the Boot Block
Finally found out how to unlock the Boot Block on the Flash Chip. It's undocumented but:
instead of:
[0x0000]=0x00
as used in the Boot Block lock sequence (documented), its:
[0x2AAA]=0xAA
This unlocks both the lower and upper boot blocks.
I16HEX
I8HEX can be upgraded to I16HEX by added the segment prefix record code (0x02).
Done.
CP/M EMU
Need to update my CP/M emulator of I16HEX as the Flash Disk is more than 64k.
Still working on this, getting close. Found a precedence error:
ROM[PAGE*0x8000+addr&0x7fff][DISK];
Must be:
ROM[PAGE*0x8000+(addr&0x7fff)][DISK];
Working better but TYPE only lists 128b of a 254b file?
Loading Some Files Crashes CP/M
I need it to work out why CP/M crashed when I exit some (larger) but not all (generally smaller) programs.
Solved (I think). The faulty logic is that directory record size is 128b (as per Internet directory format documentation). For a 2048b block, it should be 256b per record. My directory calculations are based on 128b per record. This made CP/M load twice the required disk data, over-writing CCP. Or at least I think so, I will fine out tomorrow.
My TEST.COM program works but upon return HALTS the emulator:
$ ./myCPM_EMU
my CP/M EMU Console - Written by Alan Cooper (AlanCooper@StartMail.com)
my CP/M 2.2 V1A
A>B:
B>DIR
B: CC COM : CC COM : CC MSG : AS COM
B: LN COM : C LIB : C LIB : M LIB
B: STDIO H : MATH H : COMPILE TXT : TEST C
B: TEST COM
B>TYPE TEST.C
#include "stdio.h"
#include "math.h"
main()
char buf[80];
float r;
printf("please enter your name: ");
gets(buf);
r=sqrt(1.1);
printf("hello, %s, %f welcome to the growing community of Aztec C users\n", buf,r);
B>TEST
please enter your name: AlanX
hello, AlanX, 1.048798 welcome to the growing community of Aztec C users
my CP/M 2.2 V1A
8085 halted
So an improvement but CCP is still being trashed(?).
Reloaded all the Flash Disks and ran the machine.
Still the same "my CPM 2.2 V1A" loop. I can run 8k program and return safely but not my 14k TEST program. I must be double loading (28k) and wiping out CCP. Must be something I have to change somewhere.
I can't work it out! Spent a whole day on this. Thinking I should go back to 1kb blocks.
My CP/M V2
The board is ready and I have the components. For version 2 I am still using software serial but RAM is increased to 56kb (enough for the C compiler) and the Flash disk capacity is increased to 512kb (e.i. W29C040-90B).
New Flash ROM Programmer
Need to design a new flash ROM programmer using a MEGA 2560.
AlanX
