Finally Working Correctly
A project log for My CP/M Version 1A
I decided to do a minor upgrade to My CP/M (Version 1). Swap RST6.5 for RST7.5 and increase the FRAM disk capacity from 32k to 256k.
agpcooperagp.cooper 06/29/2021 at 13:350 Comments
Finally
I worked my way through Grant Searle's CBIOS and compared it to my CBIOS. I found a two disk set up errors but the main problem was not copying CP/M properly upon a Warm Boot. All fixed and CP/M now works properly.
I also redesigned my Flash ROM Programmer so I can upload a single (large) HEX8-16 file to the Flash ROM (i.e. W29C020). This save a huge amount of time over the old Flash ROM Programmer which uploaded just 16kb blocks in firmware.
Here is the happy MyCP/M V2 and the Flash ROM Programmer:
AlanX
