Current State
03/04/2021 at 17:24 • 0 commentsThe Simulator is usable for easy math programs and simple algorithms. I programmed a simple add program and the fibonacci program to demonstrate. It can also give simple ASCII output with a "Terminal". I now want to program the simulated CPU to support loading from and writing to any address in memory. With this I would be able to continue work on my already started native assembler for the simulator. Multicore is still also planned... I would be very happy if some of you guys give it a try on github, if you have any questions I'd be happy to answer them. -
Decisions...
12/19/2020 at 10:21 • 0 commentsI decided to not realize this project as a circuit. It will stay as a Software Project. The Simulator will be extended to support multicore design. -
Researching and learning
07/26/2020 at 19:48 • 0 commentsI now finished a first raw simulator. I am not quite happy with the overall design yet. I will research for some improvements for the architecture before continuing to design. Already have some improvement ideas but it takes more time.
Regarding the Image
07/02/2020 at 09:39 • 0 commentsTo get a better idea of what I have to implement in code, I first created a rough design sketch in logisim.
This does not show how the simulator will work nor how the theoretical function of the processor is.
