Alternative Design
08/27/2020 at 15:48 • 0 commentsInstead of the joint based design from previous prototypes, this prototype focuses on using only printed parts for joints. This style of joint won't see use in the main ARX Hand Project designs but will be suitable for general community print set ups where designs that are fully 3D printed are desired.
Third Prototype
08/25/2020 at 16:33 • 0 commentsThis prototype further improves on the previous prototype by
Second Prototype
08/25/2020 at 16:33 • 0 commentsThis prototype implements a more common approach used in injection moulding for joints that I often seen in Gundam Model kits.
Initial Prototype
07/04/2020 at 19:46 • 0 comments25/12/2019
This prototype uses a mix of an requiring drilling of a 3mm drill as well as some design features to improve consistency from a single pass with a drill. Previous ARX Hand Project developments consisted of just drilling out a 3mm printed hole to provide for a friction fit. This drilling method wasn't particularly reliable as multiple passes may be needed to have a tight but not overly tight fit.
