1Run a Program
#include
#include
LiquidCrystal_I2C lcd(0x27,20,4);
//this values will help us to choose the time
long last_change;
long last_value;
long timer_value;
void setup()
//inti lcd
lcd.init();
//turn on backlight
lcd.backlight();
pinMode(A0, INPUT);
pinMode(8, OUTPUT);
void loop()
//if the value was changed less than 5 seconds ago this loop will work
while(millis() - last_change < 5000){
timer_value = map(analogRead(A0), 0, 1023, 1, 120);
if(timer_value != last_value){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Timer");
lcd.setCursor(0,1);
lcd.print(timer_value);
last_value = timer_value;
last_change = millis();
delay(10);
//after 5 seconds this will happen
lcd.clear();
lcd.print("starting...");
delay(3000);
long target = last_change + (timer_value * 60 * 1000);
//and then it will start displaying how much time there is until end of counting
while(millis() < target){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Time left:");
lcd.setCursor(0, 1);
lcd.print((target - millis()) / 1000 / 60);
delay(50);
//and few beeps at the end
for(int a = 0; a < 10; a++){
digitalWrite(8, HIGH);
delay(500);
digitalWrite(8, LOW);
delay(500);
while(1);
hIOTron
