The Cyclone V FPGA (PN: 5CEFA2F23) has a lot more internal SRAM than the EP4CE15. I was able to add 96KB of internal SRAM. Due to the TS2 memory map the new memory could not be contiguous with the lower RAM. That's because the Tutor ROM is located at 0x008000-0x00FFFF. The new internal SRAM is at 0x200000-0x217FFF.
I also got the external SRAM working - well sorta working. It is only 8-bits and the 68000 CPU does not do dynamic bus sizing so it has to be accessed as bytes. But I tested some locations and they worked fine. The External SRAM is from 0x300000-0x3FFFFF.
