In the last log I got the toolchain working on my Raspberry Pi to cross compile code for the 68K CPU.
In this log, I will try and assemble the TUTOR 1.3 code using the toolchain. I am using FileZilla to transfer the file to the Raspberry Pi. Here is the command line to assemble the code (adapted version of Jeff Tranter's command line):
./m68k-coff-as -m68000 -alms -a=tutor13.lst -o tutor13.o tutor13.s
When I run it I get a lot of errors starting with:
./m68k-coff-as -m68000 -o tutor13.o tutor13.s tutor13.s: Assembler messages: tutor13.s:5812: Error: value out of range tutor13.s:5812: Error: Value of -132 too large for field of 1 bytes at 0xf82bad tutor13.s:6822: Error: value out of range tutor13.s:6822: Error: Value of 142 too large for field of 1 bytes at 0xf83421 tutor13.s:6838: Error: value out of range tutor13.s:6838: Error: Value of 162 too large for field of 1 bytes at 0xf83449
Line 5812 is a short branch instruction:
BSR.S COMMAS20
I thought short branches are 16-bits? If so, then a branch of -132 should not be too far away. Same for the rest of the list. I wonder if there's a missing option on the assemble line to specify the size of the BRA.S instruction?
./m68k-coff-as -help Usage: ./m68k-coff-as [option...] [asmfile...] Options: -a[sub-option...] turn on listings Sub-options [default hls]: c omit false conditionals d omit debugging directives h include high-level source l include assembly m include macro expansions n omit forms processing s include symbols =FILE list to FILE (must be last sub-option) --alternate initially turn on alternate macro syntax -D produce assembler debugging messages --defsym SYM=VAL define symbol SYM to given value -f skip whitespace and comment preprocessing -g --gen-debug generate debugging information --gstabs generate STABS debugging information --gstabs+ generate STABS debug info with GNU extensions --gdwarf-2 generate DWARF2 debugging information --help show this message and exit --target-help show target specific options -I DIR add DIR to search list for .include directives -J don't warn about signed overflow -K warn when differences altered for long displacements -L,--keep-locals keep local symbols (e.g. starting with `L') -M,--mri assemble in MRI compatibility mode --MD FILE write dependency information in FILE (default none) -nocpp ignored -o OBJFILE name the object-file output OBJFILE (default a.out) -R fold data section into text section --statistics print various measured statistics from execution --strip-local-absolute strip local absolute symbols --traditional-format Use same format as native assembler when possible --version print assembler version number and exit -W --no-warn suppress warnings --warn don't suppress warnings --fatal-warnings treat warnings as errors --itbl INSTTBL extend instruction set to include instructions matching the specifications defined in file INSTTBL -w ignored -X ignored -Z generate object file even after errors --listing-lhs-width set the width in words of the output data column of the listing --listing-lhs-width2 set the width in words of the continuation lines of the output data column; ignored if smaller than the width of the first line --listing-rhs-width set the max width in characters of the lines from the source file --listing-cont-lines set the maximum number of continuation lines used for the output data column of the listing 680X0 options: -l use 1 word for refs to undefined symbols [default 2] -m68000 | -m68008 | -m68010 | -m68020 | -m68030 | -m68040 | -m68060 | -m68302 | -m68331 | -m68332 | -m68333 | -m68340 | -m68360 | -mcpu32 | -m5200 | -m5202 | -m5204 | -m5206 | -m5206e | -m521x | -m5249 | -m528x | -m5307 | -m5407 | -m547x | -m548x | -mcfv4 | -mcfv4e specify variant of 680X0 architecture [default 68020] -m68881 | -m68882 | -mno-68881 | -mno-68882 target has/lacks floating-point coprocessor [default yes for 68020, 68030, and cpu32] -m68851 | -mno-68851 target has/lacks memory-management unit coprocessor [default yes for 68020 and up] -pic, -k generate position independent code -S turn jbsr into jsr --pcrel never turn PC-relative branches into absolute jumps --register-prefix-optional recognize register names without prefix character --bitwise-or do not treat `|' as a comment character --base-size-default-16 base reg without size is 16 bits --base-size-default-32 base reg without size is 32 bits (default) --disp-size-default-16 displacement with unknown size is 16 bits --disp-size-default-32 displacement with unknown size is 32 bits (default) Report bugs to
Looking at the difference between BRA and BRA.S shows that the branch is being treated as a byte offset instead of a short offset.
5810 ???? 6100 F70A BSR EAZ 5811 5812 ???? 617C BSR.S COMMAS20 5813
Toolchain Problem
It looks like the assembler did install but the C compiler is missing and it really would be worthwhile to have a C cross-compiler that lets me generate code under Windows. Trying a different way of making the gcc toolchain (Building the 68000 cross compiler - Automated).
Another Try at the GNU GCC Toolchain
I went onto the 68000 Assembly Language programming group on facebook and got a pointer to Steve Moody's gcc for 68k github page that eventually got me running on the GCC toolchain.
The toolchain is running in VirtualBox under Linux.
Steve has a Makefile that does most of the work The one thing I did have to change was to set the variable PWD to the path to install. I got my son who's a wiz at all things Linux to help me figure out why it was crashing.
PWD = /home/doug/m68k-elf-toolchain
If you try it there are certainly better ways and your path will not be the same. You can get the path with the pwd command but you have to be in the right folder in terminal.
I was rewarded with a GCC toolchain that assembled code correctly.
I then installed srecord with:
sudo apt install srecord
That installs the srecord program srec_cat. It installed version 1.58.D001 on my install.
Typing the line to assemble:
/opt/m68k-elf/bin/m68k-elf-as monitor.s -o monitor.o
Created code.
