PCBA Coating
10/29/2021 at 01:00 • 0 comments -
V3 Version
10/25/2021 at 02:32 • 0 commentsGreat improvements on Makerfabs Lora Soil Moisture Sensor V3!!!
- TLC555 removed, while the Atmega328P(D9/Timer1) generates the 2 MHz pulse (only during the measurement phase, switching off afterward), for capacitive moisture measurement.
- Unique ID by default, for easy/fast usage as getting it on hand.
- Ultra-low-power consumption design on hardware& firmware, 7.1uA in sleeping mode, minimum 2 years working time with battery 2x AAA.
- Improved J3166 water-proof paint to enhance the lifetime of usage. It has outstanding moisture-proof, salt fog proof and insulation properties.
For more detail, please check here.
Schematic
07/11/2020 at 09:07 • 0 comments1. There the D5 to turn On/Off the power of 555 and the temperature sensor(AHT10), that you do not always need to check.
2. TLC555 to generate the wave , about 400K.
3. Atmega328, works in 3.3V 8M .
Makerfabs
