The USB Thermal Monitor is a very simple circuit combining a Arduino Pro Micro, AM2302 temperature and humidity sensor and a 0.91 Inch I2C SSD1306 OLED Display. It uses the built in USB serial connection on the Pro Micro to communicate with a host computer to allow logging of temperature and humidity data.
Serial Data Format
Every 2 seconds the current humidity and temperature is output on the serial port at 9600 baud. It is output as a string with the following format:
<fw ver>,<humidity %>,<temperature in Celsius>\n
Example Output:
1.0,43,22.5
Physical Display
I wanted to be able to view the temperature as well as log it so the circuit supports a simple i2c display. The display is updated every 2 seconds with the latest readings.
By default the firmware uses Fahrenheit for the display but that would be easily changed.
Dan Polnoff
Bonez
misha
hIOTron
A $4 NodeMCU can send the data to a web page on your phone for zero display cost and zero I/O. It can also send the data to a cloud spreadsheet viewable from anywhere.
https://hackaday.io/project/172151-home-automation-with-nodemcu
