LED Mask to light up these dark times. APA102 strips are controlled by an ATtiny84a.
Pattern Lining Fabric.pdfSewing pattern for inner liningAdobe Portable Document Format - 12.36 kB - 07/21/2020 at 02:05 |
Wearing a mask during the COVID-19 pandemic is a must to slow the spread and for that reason there was a call in April to all mask makers to make masks. A good reason for me to try out my new sewing machine. I found a template on the internet and made my first mask the next hour. After making masks for my wife, some friends and the local nursing home it was time to take it to the next level.
I'm not new to using LED's in wearables: https://hackaday.io/project/162435-board-for-modular-led-wearables. So I decided to use that same template I was using for the other masks, but replaced the front with netting. Placed some nuFoam between the fabrics and added one of those boards from the other project. It worked and look pretty cool, but wearing this mask was very uncomfortable. The board was large and so was the battery that was just laying around. And after the battery ran empty I was not even able to get to the charging port.
Download the "Pattern Lining Fabric.pdf" from the files section. Print the pattern on a letter size paper. Cut out two pieces of fabric by following the solid dark line. I used an old sheet or you can use a T-shirt when you have no other fabric laying around.
Fold the top of the battery and LIPO charger pockets and sew it together as follows:
Create the pocket by folding the end of the fabric to get a clean edge, and fold it over again before sewing the edge:
Now fold the back edge over twice and sew the end. For decoration I usually sew shown in the following pictures:
Make sure the battery fits tight in the pocket so that it will not bounce around.
Do the same for the second fabric but make sure it is mirrored from the first half. After completing the second half make sure it fits the LIPO charger. Put both pieces together with the pockets facing out and sew the front together:
