1Cut the fabric for the inner lining
Download the "Pattern Lining Fabric.pdf" from the files section. Print the pattern on a letter size paper. Cut out two pieces of fabric by following the solid dark line. I used an old sheet or you can use a T-shirt when you have no other fabric laying around.
Fold the top of the battery and LIPO charger pockets and sew it together as follows:
Create the pocket by folding the end of the fabric to get a clean edge, and fold it over again before sewing the edge:
Now fold the back edge over twice and sew the end. For decoration I usually sew shown in the following pictures:
Make sure the battery fits tight in the pocket so that it will not bounce around.
Do the same for the second fabric but make sure it is mirrored from the first half. After completing the second half make sure it fits the LIPO charger. Put both pieces together with the pockets facing out and sew the front together:
Sander van de Bor
