Hackaday.io Hackaday.io
Sign up Log in
Serial Plotter
My Serial Plotter (written on Python) what does what I like.
tauno-erikTauno Erik
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
0 comments
11 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2.4k
0
11
8
Team (1)
  • tauno-erikTauno Erik
Join this project's team
  • Tauno Serial Plotter
  • snapcraft.io
  • flathub.org
ongoing project
Software
serial plotter python serial plotter
This project was created on 07/23/2020 and last updated 5 years ago.
Description
This is my standalone serial plotter. I like to use Arduino, Esp866 etc. and then I started to learn python and decided to make something useful. Something that I will use and what is missing now for me. Although Arduino Ide contains serial plotter. It is a little bit different.Written in Python 3 and Qt5. It is basically my first GUI application ever.Incoming data should be a string. Ending with newline character. Number can be separated with almost any character.Like:label2la15be17el28/31/42/54 78ora2b1.5c1.7d2.8/3.1/4.2/5.4 7.8But not with - unless it is a negative number:5-10-22-33-40-55-62-75Script will extract all numbers and generate graph.Tested on Ubuntu 19.10 and Windows 10.Sourcecode and run instructions are on Github: https://github.com/taunoe/tauno-serial-plotter
Project Logs
Collapse
  • Snap
    Tauno Erik • 01/09/2021 at 18:17 • 0 comments
    My Serial Plotter app is now in snap store.
View project log
Log In/Sign up to comment
Sign up with Github
OR
The Better Serial Plotter is a new and improved drop-in replacement for the Arduino serial plotter with many new helpful features.
Project Owner Contributor
nathanNathan
Turn an old broken TI92 as a Serial terminal (ex. for RaspPI 0w)
XtsTI92SerialTerm
franck-galliatFranck GALLIAT
Logic Analyzers with Arduino
GinLogic | Arduino DUE, UNO | GinLab
gintaras-valatkaGintaras Valatka
Arduinos are great at interfacing with hardware. TouchDesigner is great at making graphics and sound. This shows how to bring em together.
Arduino muliple data to TouchDesigner
jerry-isdaleJerry Isdale
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Serial Plotter", please tell us the reason.
Send message
Remove Member
