Switch Debouncing
08/02/2014 at 20:16 • 0 commentsI've added an analogue debounce-filter to the MIDI2VC. Some details on the digital vs the analogue approach is here: http://electev.blogspot.se/2014/08/button-debounce-analogue-vs-digital.html
Youtube presentation
07/17/2014 at 20:06 • 0 commentsI have made the youtube presentation for the Hackaday Prize: http://youtu.be/h5vtCJXsh-U
BOM cost
07/13/2014 at 14:38 • 0 commentsI tallied up the BOM and calculated the total price, and it's just under 13€. Most components were bought from Elfa-Distrelec, except the PIC, which was bought from Farnell.
One thought I had about this project was to make it cheap, which I think it is now. I chose to use RCA jacks for signal outputs. I don't beleive these jacks are commonly used in synth modules. RCA cables are easily found cheap or free in junk bins or flea markets and they should give the same signal quality as any other cable type that might be used.
Bug testing
07/11/2014 at 14:30 • 0 commentsThe project is basically done, so right now im figuring out clever ways to find bugs. The last test was using different midi channels to interact with the midi2vc. I cycled through all 16 channels using midi-ox and a midi to usb converter. All 16 channels worked equally well. Nice :-)
Project files
07/03/2014 at 20:05 • 0 comments
Johan
