Pi-KVM v3 Hat: It's alive!
10/02/2020 at 14:52 • 0 commentsSo, it seems it's working! After some PCB refactoring it will be available for the purchase as a small test batch. Then we will start mass selling.
KVMD 1.101: Migrating to libgpiod
09/17/2020 at 12:46 • 0 commentsThe main change in this release concerns the internals of Pi-KVM. About a year ago, the Linux kernel interface, which is used by most applications on the Raspberry Pi that work with GPIO, was deprecated (sysfs/gpiomem). This was replaced by the character device `/dev/gpiochipX`. It is stated that the old interface will be removed in 2020, that is, very soon. Existing GPIO libraries for Python and C will also stop working: RPi.GPIO, pigpio, wiringpi and other. It seems that the coming year will be fun for many projects that use the old library. For this reason, I got rid of RPi.GPIO and now KVMD uses libgpiod, a library for working with GPIO recommended and supported by kernel developers.
