Fume hood assembled from easily available consumer products.
A funny thought as a german speaker: You use a tote, "um eine Tote zu vermeiden". ("to avoid a dead female").
VOCs are no joke, especially for young women. It always drives me nuts when my daughter uses acetone to strip paint off the dolls she loves to modify. This is a great idea, and I'll have to see about making one for her.
Do make sure you get a large enough vent fan. Mine was 8" and ~450 CFM. It was adequate, but not by any means over-doing it.
Great project!
What blower are you using? I've in the past used bilge blowers since they have easy mounting tabs molded in and have worked well when I hook them up with a PWM controller. Bonus they are marine use so tolerant of some moisture. Can find them in 3 and 4in sizes.
In my previous uses their CFM have been enough (specs list roughly 200CFM at full tilt), but if you've found something that has better specs I'd be interested to learn what you've found for future projects.
