MABEL.step
Project File for modifications in CAD.
step -
14.16 MB -
08/03/2020 at 13:35
Download
DriverGear.stl
Gear to drive leg sections. 3D Print 4x.
Standard Tesselated Geometry -
2.55 MB -
08/03/2020 at 13:34
Download
LowerLeg.stl
3D Print LowerLeg.stl 2x
2.15 MB -
08/03/2020 at 13:34
Download
BatteryPack.stl
Housing to hold 2800mAh LiPo battery. Only one required.
973.76 kB -
08/03/2020 at 13:34
Download
BodyPanel.stl
Side panels that hold the upper servos and drive the Upper leg segments. 3D print 2x.
1005.64 kB -
08/03/2020 at 13:34
Download
BodyTop.stl
Top of the Body. 1x
302.63 kB -
08/03/2020 at 13:34
Download
Housing.stl
Bottom section of robot body. 1x
931.80 kB -
08/03/2020 at 13:34
Download
PanBracketHead.stl
Pan bracket mount for head movement mechanism. Print 1x.
1.46 MB -
08/03/2020 at 13:34
Download
UpperBody.stl
Upper body section. Print 1x
1.11 MB -
08/03/2020 at 13:34
Download
TiltBracketHead.stl
Tilt bracket mount for head movement mechanism. Print 1x.
669.42 kB -
08/03/2020 at 13:34
Download
UpperLeg.stl
Upper leg section. Print 2x - One for each leg
2.01 MB -
08/03/2020 at 13:34
Download
Wheel.stl
Wheel (Optional - own wheels can be used) - Print 2x
744.00 kB -
08/03/2020 at 13:34
Download
