HydraNFC Shield v2 is based on STMicroelectronics ST25R3916 NFC chipset which is today the most powerful and versatile NFC chipset available on the market.
HydraNFC Shield v2 is for anyone interested in Learning/Developping/Debugging/Hacking/Penetration Testing for basic or advanced NFC communications.
The firmware is open source and available on GitHub: https://github.com/hydrabus/hydrafw_hydranfc_shield_v2
Key Features of HydraNFC Shield V2 hardware (with HydraNFC v2 Antenna):
- Operating modes:
- Reader/writer
- Card emulation (Type A and Type F Tags are supported natively, other tags can be supported with Special stream and Transparent modes)
- Active and passive peer to peer
- RF communication:
- EMVCo™ 3.0 analog and digital compliant
- NFC-A / ISO14443A up to 848 kbit/s
- NFC-B / ISO14443B up to 848 kbit/s
- NFC-F / FeliCa™ up to 424 kbit/s
- NFC-V / ISO15693 up to 53 kb/s
- NFC-A / ISO14443A and NFC-F / FeliCa™ card emulation
- Active and passive peer to peer initiator and target modes, up to 424 kbit/s
- Low level mode to implement MIFARE Classic® compliant or other custom protocols
- Key features:
- 1.6W output power at 5V with Differential Antenna and Variable capacitors for NFC Automatic antenna tuning (AAT)
- Reader/writer mode range is more than 12cm for NFC-A (ISO14443A) Tags (8.5cm x 5.4cm)
- Reader/writer mode range is more than 16cm for NFC-V (ISO15693) Tags(ST25 Tag 5cm x 5cm)
- Dynamic power output (DPO) controls the field strength to stay within given limits
- Active wave shaping (AWS) reduces over-and under-shoots
- Noise suppression receiver (NSR) allows reception in noisy environment
- Integrated EMVCo 3.0 compliant EMD handling
- Automatic gain control and squelch feature to maximize SNR
- Low power capacitive and inductive card detection
- Low power NFC active and passive target modes
- Adjustable ASK modulation depth, from 5 to 40>#/li###
- Integrated regulators to boost system PSRR
- AM/PM and I/Q demodulator with baseband channel summation or automatic channel selection
- Possibility to drive two independent single ended antennas (default use differential antenna)
- Measurement of antenna voltage amplitude and phase, RSSI, on-chip supply and regulated voltages
- External communication interfaces
- 512-byte FIFO
- Serial peripheral interface (SPI) up to 10 Mbit/s (Tested with success on HydraBus v1 at 10.5Mbit/s)
- Electrical characteristics:
- Wide supply voltage and ambient temperature range (2.6 to 5.5 V from -40 °C to +105 °C, 2.4 to 5.5 V from -20 °C to +105 °C)
- Wide peripheral communication supply range, from 1.65 to 5.5 V
- Quartz oscillator operating with 27.12 MHz crystal with fast start-up
- Frequency Tolerance +/-30ppm max. (25+/-3℃)
- Operating Temperature Range -30℃ to +85℃
Key Features of HydraFW (for HydraBus v1/HydraNFC Shield v2 hardware) firmware using STMicroelectronics RFAL for ST25R3916:
This firmware is fully open source and based on HydraFW and is specific to HydraBus v1 with HydraNFC Shield v2 it use STMicroelectronics RFAL for ST25R3916
The STMicroelectronics RFAL simplifies the development of applications by encapsulating device and protocol details.
- Complete middleware to build NFC enabled applications based on the ST25R3916 device
- Supported modes:
- Reader/Writer
- P2P initiator (PCM and ACM)
- P2P target (PCM and ACM)
- Card emulation
- Support of major NFC and proprietary technologies:
- NFC-A (ISO14443A)
- NFC-B (ISO14443B)
- NFC-F (FeliCa™)
- NFC-V (ISO15693)
- P2P (ISO18092)
- ST25TB, Kovio, B’, iClass, Calypso®
- Supported protocols:
- ISO-DEP (ISO data exchange protocol, ISO14443-4)
- NFC-DEP (NFC data exchange protocol, ISO18092)
- Easy portability across different platforms (MCUs/RTOSs/OSs)
- Compliant with main RF/NFC standards:
- NFC Forum
- EMVCo™
- ISO14443
- ISO15693
- ISO18092
- MISRA C:2012 compliant
- Free, user-friendly license terms
The firmware will support low level mode to implement other custom protocols in reader/writer mode (potentially also P2P), card emulation mode and even unique real-time sniffer mode. For more details on open source firmware see https://github.com/hydrabus/hydrafw_hydranfc_shield_v2...
Benjamin Vernoux
HYuiii
Michael Wessel
