4U done
09/22/2020 at 05:31 • 1 comment![]()
After cleaning up the code a bit (I made some stupid connection between depth and height) i designed version for 3U plus 1U Intelijel, my inputs, outputs and mixer.
Meanwhile the PCBs and for the PSU came, and after some trouble (FedEx, you know) the parts as well.
So friday evening lasercutting, saturday afternoon soldering the PSU, since saturday evening i want to show it off at our hackerspace. Sounds like a reasonable deadline, and it worked out. After finding a strong enough power supply ( our bench power supply aren't, but I found an old Dell notebook PSU), finally blinkenlichten (picture form my trip home: Make Modular Jams in Trains Great Again)
Mechanical prototype done
09/06/2020 at 18:25 • 0 comments![]()
Cut the first prototype out of 4mm plywood. seems to work but it feels a bit week.
Lessons learned:- don't use HP in your OpenSCAD file, because 84 HP could also be 85.23493 HP
- aound 10cm is bit too less space when it comes plug in cables and stuff.
Next: design a powersupply/busboard.
Tillo
