I am posting this as an update of whats going on.
I am going to attempt to assemble the PCBs this week end and hopefully program it shortly after. I also realized that I currently don't have a good enough 3.3v supply to actually run/program the repeater board once assembled. So I guess its time to design up a power supply board that can power the repeater and also the future Power Amplifier board.
I have also yet to fix the resistor issue on EasyEDA because I haven't assembled the PCB to know if it will actually be an issue or not.
