A project log for Simple FM Repeater
A simple home brew FM ham radio repeater.
I finally assembled the board.
I will be trying to program it over the next few weeks.
Programming software here - https://github.com/lightaprs/LightAPRS-W-1.0
There is configDra818() in the .ino file.
I actually already have a library I am going to use. If this was a 2m repeater I could have it set up for working as an APRS Digipeater also. (Because I could program the RX on the TX side and the TX on the RX side.)
Yes, delete it Cancel
