1Step 1
If you would like to build one of these for yourself here is the breadboard layout
You will need to burn the arduino bootloader onto the atmega328 so that you can upload the sketch from my github HERE. You are free to use what you want from this so if you don't want the speaker or as many buttons just change the circut to suit.
3Step 3
Then all you need to do is populate the board and cram it all into the enclosure after cutting the nessasery holes out
facelessloser
