I know it's not the tidiest way of doing this conversion but I have looked in this matter extensively and I did find other , more "elegant" solution for the transplant.
Please refer to the following video to see what was my other alternative and the reason I didn't do it.
In the comments of the video you will find technical details about the parts you will need for the alternative transplant solution.
In this blog post we are going to go over copper wires and the different types of wire, their strengths, weaknesses, and how they compare. Copper is a type of metal that has many uses. It can be used for top dissertation writing services wiring in electronics as well as other things like plumbing or roofing. In this blogpost we will go over some basics about copper cables such as what they are made of and why it's important to know when buying them.
