Tubular door bell
A copper pipe door bell with woodpecker used as hammer.
Tubular door bell. Five 1/2" copper pipe cut for pentatonic scale. 5 woodpecker sculpted in wood used as hammers. Apparent electronic circuit.
JPEG Image - 4.13 MB - 09/20/2020 at 01:19
Preview
JPEG Image - 4.21 MB - 09/15/2020 at 02:29
Preview
Portable Network Graphics (PNG) - 3.85 MB - 09/15/2020 at 02:28
Preview
schematic.pdf
Adobe Portable Document Format - 95.75 kB - 09/15/2020 at 02:24
Preview
copper tubings cut in length for pentatonic scale
Portable Network Graphics (PNG) - 7.75 MB - 09/05/2020 at 15:31
Preview
View all 6 files
  • project abandoned
    Jacques09/20/2020 at 01:28 0 comments
    The application code written in Forth was completed and the circuit was also completed except for the power supply. It is a dead bug style.  But this is a fail the copper pipes sound is not loud enough. It can't be used for a doorbell.
    The servo-motor are as noisy as the pipes.  Too bad, no more money and time on this project.
  • mechanical assembly
    Jacques09/15/2020 at 02:37 0 comments
    Mechanical assembly almost completed
    stm8 eForth flashed on MCU.  I started working on application written in Forth.
  • initial concept failed
    Jacques09/07/2020 at 02:05 0 comments
    Today I tested the initial concept and it failed. The tubes can't be supported on cross bars it kill sound. I revised the concept. The copper tubes will be suspended by strings inside a frame as shown here.
    Not visible on this drawing, there is a string at the bottom too otherwise the pipes would swing when hammered.
  • servo-motor test
    Jacques09/05/2020 at 15:09 0 comments
    Copper tubing cut in length, wookpecker hammers sculpted and painted. The following video is a hammer test. The project use small SG90 servo-motors to animate the woodpeckers.
  • github repo created
    Jacques08/31/2020 at 15:13 0 comments
    I created a github repository for this project
    tubular door bell project repository
View all 5 project logs
