project abandoned
09/20/2020 at 01:28 • 0 commentsThe application code written in Forth was completed and the circuit was also completed except for the power supply. It is a dead bug style. But this is a fail the copper pipes sound is not loud enough. It can't be used for a doorbell.
The servo-motor are as noisy as the pipes. Too bad, no more money and time on this project.
mechanical assembly
09/15/2020 at 02:37 • 0 commentsMechanical assembly almost completed
stm8 eForth flashed on MCU. I started working on application written in Forth.
initial concept failed
09/07/2020 at 02:05 • 0 commentsToday I tested the initial concept and it failed. The tubes can't be supported on cross bars it kill sound. I revised the concept. The copper tubes will be suspended by strings inside a frame as shown here.
Not visible on this drawing, there is a string at the bottom too otherwise the pipes would swing when hammered.
servo-motor test
09/05/2020 at 15:09 • 0 commentsCopper tubing cut in length, wookpecker hammers sculpted and painted. The following video is a hammer test. The project use small SG90 servo-motors to animate the woodpeckers.
github repo created
08/31/2020 at 15:13 • 0 commentsI created a github repository for this project
