initial concept failed
A project log for Tubular door bell
A copper pipe door bell with woodpecker used as hammer.
jacquesJacques 09/07/2020 at 02:050 Comments
Today I tested the initial concept and it failed. The tubes can't be supported on cross bars it kill sound. I revised the concept. The copper tubes will be suspended by strings inside a frame as shown here.
Not visible on this drawing, there is a string at the bottom too otherwise the pipes would swing when hammered.
