LibreGates_20220528-1.tbzBetter XML parserx-bzip-compressed-tar - 227.77 kB - 05/28/2023 at 04:15 |
LibreGates_20201216.tbzbetter driver conflict detectionx-bzip-compressed-tar - 227.47 kB - 12/17/2020 at 03:02 |
LibreGates_20201209.tbznetlist probe v2B : passes more testsx-bzip-compressed-tar - 224.35 kB - 12/09/2020 at 05:18 |
LibreGates_20201202.tbznetlist probe okx-bzip-compressed-tar - 224.07 kB - 12/02/2020 at 03:17 |
LibreGates_20201128.interim.tbzrebuilding the netlist probe code.x-bzip-compressed-tar - 234.94 kB - 11/28/2020 at 09:32 |
LibreGates_20201121.tbzNew wrapper generator, new brute-force test/benchmark...x-bzip-compressed-tar - 232.98 kB - 11/21/2020 at 20:17 |
LibreGates_20201116.tbzFaster fault test with parallel execution, weird bash bug squashed.x-bzip-compressed-tar - 199.16 kB - 11/16/2020 at 03:17 |
LibreGates_20201108.tbzself-tests pass OK, OSU barely started, wrapper generator OK with split source files, netlist-probe remains to be done, some obsolete stuff will be removed later.x-bzip-compressed-tar - 198.16 kB - 11/08/2020 at 05:05 |
OSU_FreePDK.tar.gzcopy from https://vlsiarch.ecen.okstate.edu/flows/FreePDK_SRC/gzip - 1.69 MB - 09/20/2020 at 18:38 |
LibreGates_20200913.tbzAnother interim : wrapper generator finally working ! but the VHDL side must be updated.x-bzip-compressed-tar - 195.26 kB - 09/13/2020 at 00:44 |
LibreGates_20200905.tbzinterim release, not for normal use.x-bzip-compressed-tar - 193.58 kB - 09/04/2020 at 23:21 |
LibreGates_20200902.tbzmoved directories around... no big deal but every step counts.x-bzip-compressed-tar - 186.44 kB - 09/02/2020 at 20:10 |
LibreGates_20200801.tgzFirst release - was to be VHDL library v2.10 but ...(don't bother the wrong month number) x-compressed-tar - 201.40 kB - 09/01/2020 at 05:38 |
