Raspberry Pi 4 pocket computer
Small form factor device, built on the raspberry pi 4 and hyperpixel 4.0.
I have always wanted a pocket-able linux device. I plan to do further iterations but thought it was good to start off with the raspberry pi. I was able to get the thickness down to 2cm including the 3D printed case. To do this, I desoldered the GPIO pins, USB ports, DSI, camera and headphone connectors on the raspberry pi. I also removed the the female header and I2C breakout on the hyperpixel. I took two 20pin lengths of right angled pins and soldered them between the remaining pads of the hyperpixel and the Pi's GPIO. I used a 3000mah lipo for power and Seed Studios lipo rider plus to bump it up to 2amps. I removed the USB port on the lipo rider and trimmed the end of the board to save space. Other than the power switch, there was no other assembly.
It's not particularly usable given the screen size.
Dimensions:
W=63cm, L=111cm, H=2cm
Components:
Raspberry Pi 4 4GB
Pimoroni Hyperpixel 4.0 Touch
Seed Studio Lipo Rider Plus
3000mah Lipo
Power switch
  • 1 × Raspberry Pi 4GB
  • 1 × Pimoroni Hyperpixel 4.0 Touch
  • 1 × Seed Studio Lipo Rider Plus
  • 1 × 3000mah Lipo
  • 1 × Power switch
Tom Nardi wrote 09/07/2020 at 01:38 point
Looks great, impressive to see what people are able to do in the DIY portable space these days.
Rob Brennan wrote 09/07/2020 at 13:23 point
Thanks Tom, appreciate it!
