21 Tooth Herringbone Gear Flexi.stl
Standard Tesselated Geometry -
10.47 MB -
09/06/2020 at 23:18
Download
144 Tooth Herringbone Gear Base Mount.stl
10.12 MB -
09/06/2020 at 23:18
Download
17 Tooth Herringbone Gear Flexi.stl
10.12 MB -
09/06/2020 at 23:18
Download
64 Tooth Herringbone Gear.stl
7.73 MB -
09/06/2020 at 23:18
Download
Pan Mount.stl
2.52 MB -
09/06/2020 at 23:17
Download
Tilt U-Mount.stl
1.07 MB -
09/06/2020 at 23:17
Download
Pan Mount Bearing Clamp.stl
1.42 MB -
09/06/2020 at 23:17
Download
Hall Effect Stepper Mount.stl
1.62 MB -
09/06/2020 at 23:17
Download
Gear Side Support.stl
1.12 MB -
09/06/2020 at 23:17
Download
Idle Side Support.stl
625.73 kB -
09/06/2020 at 23:17
Download
Base Mount Bearing Clip Ring.stl
548.54 kB -
09/06/2020 at 23:17
Download
2040 belt clamp side 2.stl
2.30 MB -
09/06/2020 at 23:17
Download
2040 slider carriage top.stl
1.48 MB -
09/06/2020 at 23:17
Download
2040 slider carriage bottom.stl
1.73 MB -
09/06/2020 at 23:17
Download
2040 hall clamp.stl
1.01 MB -
09/06/2020 at 23:17
Download
2040 belt clamp side 1.stl
2.31 MB -
09/06/2020 at 23:17
Download
2040 support leg.stl
1.36 MB -
09/06/2020 at 23:17
Download
belt clamp lever m3 hole.stl
970.52 kB -
09/06/2020 at 23:17
Download
2040 foot mould.stl
405.84 kB -
09/06/2020 at 23:17
Download
belt clamp lever.stl
528.50 kB -
09/06/2020 at 23:17
Download
3mm to 5mm wheel bearing spacer centred.stl
826.57 kB -
09/06/2020 at 23:16
Download
144 Tooth Herringbone Gear Base Mount.stp
stp -
3.55 MB -
09/06/2020 at 23:16
Download
64 Tooth Herringbone Gear.stp
stp -
1.51 MB -
09/06/2020 at 23:16
Download
21 Tooth Herringbone Gear Flexi.stp
stp -
518.28 kB -
09/06/2020 at 23:16
Download
127 x 146.05 x 12.7mm Printable Bearing Cage Part 3.stp
stp -
679.86 kB -
09/06/2020 at 23:16
Download
Pan Mount Bearing Clamp.stp
stp -
432.67 kB -
09/06/2020 at 23:16
Download
3mm to 5mm wheel bearing spacer centred.stp
stp -
11.79 kB -
09/06/2020 at 23:16
Download
Tilt U-Mount.stp
stp -
125.03 kB -
09/06/2020 at 23:16
Download
Idle Side Support.stp
stp -
50.30 kB -
09/06/2020 at 23:16
Download
17 Tooth Herringbone Gear Flexi.stp
stp -
432.39 kB -
09/06/2020 at 23:16
Download
Hall Effect Stepper Mount.stp
stp -
69.75 kB -
09/06/2020 at 23:16
Download
Gear Side Support.stp
stp -
82.69 kB -
09/06/2020 at 23:16
Download
5mm to 8mm shaft spacer.stp
stp -
20.14 kB -
09/06/2020 at 23:16
Download
Base Mount Bearing Clip Ring.stp
stp -
83.41 kB -
09/06/2020 at 23:16
Download
belt clamp lever.stp
stp -
63.77 kB -
09/06/2020 at 23:16
Download
2040 slider carriage top.stp
stp -
297.41 kB -
09/06/2020 at 23:16
Download
2040 belt clamp side 1.stp
stp -
294.76 kB -
09/06/2020 at 23:16
Download
2040 slider carriage bottom.stp
stp -
128.95 kB -
09/06/2020 at 23:16
Download
2040 support leg.stp
stp -
185.67 kB -
09/06/2020 at 23:16
Download
2040 belt clamp side 2.stp
stp -
294.05 kB -
09/06/2020 at 23:16
Download
2040 hall clamp.stp
stp -
28.46 kB -
09/06/2020 at 23:16
Download
127 x 146.05 x 12.7mm Printable Bearing Part 2.stp
stp -
15.71 kB -
09/06/2020 at 23:16
Download
127 x 146.05 x 12.7mm Printable Bearing Part 1.stp
stp -
23.17 kB -
09/06/2020 at 23:16
Download
