Hackaday.io Hackaday.io
Sign up Log in
ProVol-- My 1ppm DAC accuracy Voltage Reference
This project is based on MAX5719A from Maxim. Hopefully, This will the most easily programable voltage reference.
sushisongrensushisongren
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 2
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
845
0
4
4
Team (1)
  • sushisongrensushisongren
Join this project's team
ongoing project
MISC
dac voltage reference MAX5719 1PPM DAC 1PPM
This project was created on 09/11/2020 and last updated 6 years ago.
Description
ProVol is based on MAX5719A from MAXIM. Hopefully, This will the most easily programable voltage reference. Since the calibration of my voltage reference could be difficult to me and most of people. I may try my best to make this reference could be reliable for the 16&18 bits system.
The final version of ProVol will have the listed characteristics:
Shielded by a aluminium case
Banana jack
Internal temperature sense with TMP117(0.1℃ accuracy)
MCU inside
Controlled by an encoder
Large OLED/IPS LCD display
USB-C socket for the communication with PC.
Files
MAX5719_Core_V1.0.pdf
sheet
Adobe Portable Document Format - 362.38 kB - 05/31/2021 at 22:31
Preview
Components
  • 1 × MAX5719A
  • 1 × TMP117
Project Logs
Collapse
  • the output of my test board
    sushisongren • 09/11/2020 at 02:44 • 3 comments
    测试板
  • Test board finished
    sushisongren • 09/11/2020 at 02:39 • 0 comments
    I just finished the test board. The reference of the test boar is REF5040 from TI. I used the 4.096V in my code, but the real voltage is 4.0965V(24℃). I didn’t do any calibration or adjustment in my code. As you can see, the Initial accuracy of the MAX5719A is great.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
A tester that can be used by high school students to test the batteries for capacity.
Project Owner Contributor
12V Battery Tester
willbadenwillbaden
An Arduino Shield using the Maxim MAX11300 for 20 Programmable Mixed-Signal I/O with 12-Bit ADC, 12-Bit DAC, Analog Switches, and GPIO
PIXI Analog Shield
magicwolfiMagicWolfi
USB to UART converter, with Voltage Translator
Debug Board with Voltage Translator
saimonSaimon
A test board for generating high voltages for ESD tolerance testing.
ESD Generator
staf-verhaegenStaf Verhaegen
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ProVol-- My 1ppm DAC accuracy Voltage Reference", please tell us the reason.
Send message
Remove Member
