29.12.2020 - Voron Switchwire - Afterburner - Extruder Motor
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
dareknorwayDarekNorway 12/28/2020 at 14:560 Comments
Voron Switchwire - Afterburner - Extruder Stepper Motor
Voron Switchwire - Afterburner - Extruder Stepper Motor - Back View
Voron Switchwire - Afterburner - Extruder Motor ready to assembly on 3D Printer
Voron Switchwire - Afterburner - Extruder Motor Parts1. StepperOnline NEMA 17 Stepper Motor 17HS08-1004S 20mm 1A 16Ncm(22.6oz.in)
2. 3D Printed Extruder Motor Back Plate with Bolts and M3 insert nuts
3. 3D printed Connector Cover and Cable Chain Anchor. Two of four bolts M3x14mm that came with the Stepper Motor will be swapped to M3x20mm
