Voron Switchwire GitHub >>> https://github.com/VoronDesign/Voron-Switchwire
Voron Switchwire - DarekNorway Build Log
Enclosure Vorender5 v20.pngPortable Network Graphics (PNG) - 69.25 kB - 02/16/2023 at 23:10 |
VSW_Feed_Slot_Clamp_Top.stlhttps://hackaday.io/project/174810-voron-switchwire-3d-printer/log/200085-voron-switchwire-upgrade-feed-slot-clampStandard Tesselated Geometry - 1.33 MB - 11/06/2021 at 13:42 |
VSW_Feed_Slot_Clamp_Bottom_3mm_3mm.stlhttps://hackaday.io/project/174810-voron-switchwire-3d-printer/log/200085-voron-switchwire-upgrade-feed-slot-clampStandard Tesselated Geometry - 44.51 kB - 11/06/2021 at 13:42 |
VSW_Feed_Slot_Clamp_Bottom_4mm_3mm.stlhttps://hackaday.io/project/174810-voron-switchwire-3d-printer/log/200085-voron-switchwire-upgrade-feed-slot-clampStandard Tesselated Geometry - 66.21 kB - 11/06/2021 at 13:42 |
acrilic_enclosure_side_walls_support_v2_x2.stlStandard Tesselated Geometry - 113.95 kB - 03/14/2021 at 15:55 |
I have used double-sided adhesive 0.5mm thick black foam 20mm tape to stick the 3D printed hinges to the glass panels enclosure.
Fasteners i have used:
2x M3x12mm Screw Bots and 2x Brass Hot Melt Inset Nuts M3 X D5.0 X L4.0
STL files you can find on my thingiverse https://www.thingiverse.com/thing:5100443/files
https://hackaday.io/project/174810/components
Voron Switchwire - Y-axis Sensorless Homing - TMC2209, G28.
X axis - Microswitch Endstop
Y axis - Sensorless (TMC2209 Stepper Motor Driver Virtual Endstop)
Z axis - Inductive Probe
BTT SKR mini E3 V2.0 + Raspberry Pi4 8GB + Octoprint + Octopi + Klipper
printer.cfg
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
step_distance: 0.0125
###Sensorless Homing
#endstop_pin: ^PC1
endstop_pin: tmc2209_stepper_y:virtual_endstop
homing_retract_dist: 0
###End Sensorless Homing
position_endstop: 227
position_min: 0
position_max: 227
homing_speed: 70
homing_positive_dir: true
[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
uart_address: 2
microsteps: 16
run_current: 0.5
hold_current: 0.3
interpolate: True
stealthchop_threshold: 250
diag_pin: ^PC1
driver_SGTHRS: 170
Voron Switchwire - PLA Spiral Vase Mode Printing
Components: https://hackaday.io/project/174810/components
https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
Thomas
DarekNorway
Made In workshop
Nice! Are you happy with the results in terms of print quality?
