Voron Switchwire Upgrade - 4mm Glass Enclosure
11/14/2021 at 13:15 • 0 commentsI have used double-sided adhesive 0.5mm thick black foam 20mm tape to stick the 3D printed hinges to the glass panels enclosure.
Voron Switchwire Upgrade - Feed Slot Clamp
11/06/2021 at 13:40 • 0 commentsFasteners i have used:
2x M3x12mm Screw Bots and 2x Brass Hot Melt Inset Nuts M3 X D5.0 X L4.0
STL files you can find on my thingiverse https://www.thingiverse.com/thing:5100443/files
Voron Switchwire Upgrade - Side Walls Supports
03/15/2021 at 12:57 • 0 commentsVoron Switchwire Upgrade - Acrylic side walls with additional inside supports Voron Switchwire Upgrade - Side Walls Supports file to print: https://cdn.hackaday.io/files/1748107479071040/acrilic_enclosure_side_walls_support_v2_x2.stl
https://hackaday.io/project/174810/components -
Voron Switchwire Enclosure
03/13/2021 at 15:48 • 0 commentsVoron Switchwire Enclosure made from 3mm Acrylic PMMA and 3mm Aluminium Composite Panels.
Voron Switchwire - Y-axis Sensorless Homing - TMC2209
02/05/2021 at 17:32 • 0 commentsVoron Switchwire - Y-axis Sensorless Homing - TMC2209, G28.
X axis - Microswitch Endstop
Y axis - Sensorless (TMC2209 Stepper Motor Driver Virtual Endstop)
Z axis - Inductive Probe
BTT SKR mini E3 V2.0 + Raspberry Pi4 8GB + Octoprint + Octopi + Klipperprinter.cfg
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
step_distance: 0.0125###Sensorless Homing
#endstop_pin: ^PC1
endstop_pin: tmc2209_stepper_y:virtual_endstop
homing_retract_dist: 0
###End Sensorless Homingposition_endstop: 227
position_min: 0
position_max: 227
homing_speed: 70
homing_positive_dir: true[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
uart_address: 2
microsteps: 16
run_current: 0.5
hold_current: 0.3
interpolate: True
stealthchop_threshold: 250###Sensorless Homing
diag_pin: ^PC1
driver_SGTHRS: 170
###End Sensorless Homing -
04.02.2021 - Voron Switchwire - Filament Holder and LCD Screen
02/04/2021 at 12:05 • 0 commentsVoron Switchwire - 3D Printed Filament Holder (with a piece of 4/1.75 mm PTFE Bowden Tube) 3D Printed Enclosure for Fystec - MINI12864 LCD Display Screen
Voron Switchwire 3D Printed Parts STL files: https://github.com/VoronDesign/Voron-Switchwire/tree/master/STL -
Voron Switchwire - First Print
02/04/2021 at 11:24 • 0 commentsVoron Switchwire - PLA Spiral Vase Mode Printing
Components: https://hackaday.io/project/174810/components
Voron Switchwire - Homing, G28
01/31/2021 at 13:15 • 0 commentsVoron Switchwire - Homing XYZBTT SKR mini E3 V2.0 + Raspberry Pi4 8GB + Octoprint + Octopi + Klipper -
31.01.2021 - Voron Switchwire - BTT SKR mini E3 Wiring and Crimping
01/31/2021 at 12:29 • 0 comments -
24.01.2021 - Voron Switchwire - Power Supply Wiring and Crimping
01/24/2021 at 11:29 • 0 commentsVoron Switchwire - Power Supply Wiring 230VAC, 24VDC, 12VDC, 5VDC OV DC (-)Pin of 24V PSU and 0V DC(-)Pi of 12V tied together to control both 24V and 12V devices using SKR mini E3 Board v2.0 connected to 24VDC PSU 230VAC splicing connectors - Wago 221-615, 5x 0.5...6mm2 (20...10AWG) 24V DC (+Pin) splicing connector - Wago 221-415, 5x 0.2...4mm2 (24...12AWG) Raspberry Pi 4 Power Cable USB To Type-C Charging Wire ON/OFF Switch https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
DarekNorway
