2. 3D Printed Extruder Motor Back Plate with Bolts and M3 insert nuts
3. 3D printed Connector Cover and Cable Chain Anchor. Two of four bolts M3x14mm that came with the Stepper Motor will be swapped to M3x20mm
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
