Its measurement range is from a few hertz to 6.5 Megahertz. Three measurement time intervals are also available - 0.1, 1 and 10 seconds. If we measure only rectangular signals, then there is no need for a shaping amplifier and the signal is fed directly to the digital pin 5 from Arduino.
The code is very simple thanks to the "FreqCount" library which you can also download below.
This Project was sponsored by NextPCB. You can help support me by checking them out at one of these links:
Only $7 for SMT Order:
https://www.nextpcb.com/?code=Mirko
Reliable Multilayer Boards Manufacturer:
PCB Boards 10pcs for Free:
https://www.nextpcb.com/pcb-quote?act=1
20% off - PCB Orders:
The device is very simple and consists of several components:
- Arduino Nano microcontroller
- Shaping amplifier board
- LCD display
- Input signal shape selector
- Input JACK
- and Time interval switch : we can choose three intervals 0.1 -1 -and 10 seconds .
![](https://cdn.hackaday.io/images/8271061600189312543.jpg)
As you can see in the video, the instrument is very precise in the whole range, and we can also calibrate the frequency meter with the simple procedure described below:
In the Arduino libraries folder find the FreqCount library,
in the FreqCount.cpp file find the lines:
#if defined (TIMER_USE_TIMER2) && F_CPU == 12000000L
float correct = count_output * 0.996155;
and replace them with:
#if defined (TIMER_USE_TIMER2) && F_CPU == 16000000L
float correct = count_output * 1.000000;
where 1.000000 is your correction factor, the
correction must be carried out by applying 1 MHz to the input of the frequency meter.
After changing the file, upload a new sketch to the Arduino board.
Finally, the frequency meter is built into a suitable plastic box and is another useful instrument in the electronic laboratory.
Schematic and Code are given in "files" section
