This is my GUID. If yours is the same then I'll send you the files you need to edit it's parameters.
Portable Network Graphics (PNG) -
23.69 kB -
09/16/2020 at 15:38
Preview
DMOC445.ccs
All kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.
ccs -
123.18 kB -
09/16/2020 at 15:38
Download
WYE.par
BAS Partitur Format -
4.14 kB -
09/16/2020 at 15:38
Download
DELTA.par
4.09 kB -
09/16/2020 at 15:38
Download
ccShell-3.1.8.01_setup.zip
Most recent ccShell program.
Zip Archive -
4.94 MB -
09/16/2020 at 15:38
Download
FRC-03FB-3022-004-0000.par
4.15 kB -
09/16/2020 at 15:38
Download
FRC-03FB-3022-004-0000.ccs
ccs -
121.65 kB -
09/16/2020 at 15:38
Download
CCShell2.0.zip
Old ccShell program
Zip Archive -
7.62 MB -
09/16/2020 at 15:38
Download
DMOC445_GEN2_AC55.zip
Zip Archive -
11.47 kB -
09/16/2020 at 15:38
Download
ccShell program.zip
Some other versions of the ccShell program
Zip Archive -
20.44 MB -
09/16/2020 at 15:37
Download
ccshell.zip
Zip Archive -
20.44 MB -
09/16/2020 at 15:36
Download
SFT-10-1631-000_2008_03_10.ccs
ccs -
80.50 kB -
09/16/2020 at 15:36
Download
SFT-10-1631-000_2009_12_14_withIsUVW.ccs
ccs -
85.59 kB -
09/16/2020 at 15:36
Download
SFT-10-1631-000_2008_03_10 EE2PSHighBatIsMax390.ccs
ccs -
80.50 kB -
09/16/2020 at 15:36
Download
DMOC445_144V_2010-04-30.zip
Zip Archive -
805.00 bytes -
09/16/2020 at 15:36
Download
DMOC445_156V_2010-04-30.zip
Zip Archive -
1.19 kB -
09/16/2020 at 15:36
Download
DMOC445 16-192V 2010-04-30.par
1.81 kB -
09/16/2020 at 15:36
Download
DMOC445_168V_2010-04-30.zip
Zip Archive -
1.19 kB -
09/16/2020 at 15:36
Download
2009_instructions_for_wires.zip
Zip Archive -
12.41 kB -
09/16/2020 at 15:36
Download
DMOC445_192V_2010-04-30.zip
Zip Archive -
1.19 kB -
09/16/2020 at 15:36
Download
JPEG Image -
479.77 kB -
09/16/2020 at 15:36
Preview
JPEG Image -
399.69 kB -
09/16/2020 at 15:36
Preview
Manzanita Charger Manual.pdf
Adobe Portable Document Format -
2.11 MB -
09/16/2020 at 15:35
Preview
Charger specsheet.pdf
182.95 kB -
09/16/2020 at 15:35
Preview
SKF Bearing Encoder for Insight.pdf
This is the encoder used in the AC24ls motor
146.76 kB -
09/16/2020 at 15:35
Preview
hondainsight.stl
1st gen general shape
Standard Tesselated Geometry -
8.63 MB -
09/16/2020 at 15:35
Download
CAN controlled Application Manual.pdf
5.14 MB -
09/16/2020 at 15:34
Preview
DMOC User Manual.pdf
12.46 MB -
09/16/2020 at 15:33
Preview
Pedal controlled application Manual.pdf
7.39 MB -
09/16/2020 at 15:33
Preview
ccShell-3 Manual.pdf
527.26 kB -
09/16/2020 at 15:33
Preview
