OEM european power steering fluid (15-851OEM)
Appearance: green colored light liquid
May be similar to CHF 11S. Reported here 11S should be compatible with HNBR/NBR:
SRAM oring tested in fluid:
- OD swell 20% after 24hrs (10->12mm)
- Thickness seems unchanged
- Caliper seal thickness did increase ~10%, enough to make it unusable
SRAM oring should be EPDM. So maybe 851OEM oil has very similar compatibility to standard mineral oil?
NBR oring:
- No swell
VQM (silicone):
- No swell
https://forums.mtbr.com/brake-time/o-ring-material-question-680609.html
