Swap or replace o-rings
OEM european power steering fluid (15-851OEM)
Appearance: green colored light liquid
May be similar to CHF 11S. Reported here 11S should be compatible with HNBR/NBR:
https://forums.mercedesclub.org.uk/index.php?threads/abc-valve-block-rebuild-pics-is-this-right.138407/page-2
SRAM oring tested in fluid:
SRAM oring should be EPDM. So maybe 851OEM oil has very similar compatibility to standard mineral oil?
NBR oring:
VQM (silicone):
https://forums.mtbr.com/brake-time/o-ring-material-question-680609.html
Various available fluids found online that may be appropriate for hydraulics:
Pentosin CHF 11S:
OEM power steering fluid (European):
OEM power steering fluid (Asian):
Prestone European power steering fluid:
FEBI hydraulic fluid M6162:
Synthetic DOT3 (eg lucas oil synthetic):
Advantage of synthetic:
Viscosity index: lower = change more with temperature, higher = change less.
Viscosity: higher = thicker.
Kinematic viscosity: how fast fluid is moving when force applied.
Links:
https://www.pinkbike.com/forum/listcomments/?threadid=140344&pagenum=3
https://forums.mtbr.com/brake-time/mystik-mineral-hydraulic-oil-brakes-1070783.html
https://www.ncbi.nlm.nih.gov/books/NBK304428/ (mineral oils study)
SRAM force 11sp brake caliper:
Brake lever:
Piston: 17.85mm (aka 18mm)
Piston seal sources:
Different size piston available here (26mm OD) labeled as PE: https://www.aliexpress.com/item/4000509364502.html
O-rings compatible with:
Mineral oil:
DOT5.1 brake fluid (DOT3, DOT4):
Synthetic based hydraulic oils:
Source:
Brakes that use:
View all 4 project logs
secretjedi03
ken.do
shenzhen
Simon Liu
Yes, delete it Cancel
You are about to report the project "SRAM hydraulic brake o-ring", please tell us the reason.
